Hey Rinker i redesigned your dash hnt hint hint. You may want to consider these ideas.
My chart plotter was an old Garmin 5208 and my gauges were frustrating. Speedo was tough to keep working and when it did it wasn't as accurate as gps and tachometers were always sticky. So I bought a set of gauges from Great Lakes Skipper, a Garmin 942 and some 1/2 thick starboard. I was going to fiberglass in the old hole but started looking for a glove box as i am always looking for a place to put my phone, car keys, wallet etc...Found this also on GLS. Made a few templates from card board and then pulled out my trusty router. I also found some vinyl laminate that is really close to what was already there. It was just a mat finish. So i sprayed it with polyurethane. The gauges also came with a wiring harness so i had to do some careful research and then splice it into the old wiring harness plug. All in all i like it. Having the chartplotter up in front is huge and i also like the way it turned out by adding in the glove box.
BTW, looks great!!!
Andy
do you need 2x of them for twin engines?
Incredible job by both of you!! I have had this on my radar to do, maybe this will be a good winter project!!
Diggin2day1 Did you add digital fuel and trim sensors or did yours come that way from factory?
Fuel:
3-pin Fuel tank Harness- part# 84-864218
Huge 10 pin harness from helm, follow to the T section where branches off... (3 pin plug/2 wires labeled "fuel level" (A-blk/pink tracer ..... B-light blue/blk tracer) unplug current sender and plug in new harness
Trim:
Digital trim- orange/white (bullet plug)..... Analog (orange/light blue)... Unplug analog and plug in digital.
heres a few pictures of the plug where the new fuel harness wires plug in:
Man I wish I could get that on my Volvo.
AWESOME dash MODS guys. Always wanted to redo the dash on my 342, now I've got some ideas...thanx!!
