Big Orange Filter
jaubry
                    Member Posts: 125 ✭✭
                    Seems this year we have some "odours" when we flush the head. I read up on the. Big Orange Filter. Does anyone have experience with this product? Does it work? Will it allow an easy emptying of the tank or do we need to do anything specific?
Thanks
Johnny
x
x
x
x
x
I stop a couple times during the draw down by slightly easing the nozzle to one side to let the tank breath and equalize and to see if the excessive vacuum is stressing the system. My tank vent draws thoughout the whole process but so does the bowl in the head, while simultaneously rinsing the flush system with the fresh water formerly in the bowl. Our blackwater tank hasn't ever shown signs of inverting.
The DIY vent cannister uses PELLETS so stanky outgoing air/gas can redily pass over it's cleansing and healing properties in a magical transformation. The pelletts also freely allow air to enter the tank at an unrestricted rate limited only by the diameter of the vent hose. By the way the waste vent hose is only regular old 3/4" reinforced garden hose installed at the factory which could collapse under the right conditions.
Here's the vent filter I use below. I'd show off the $100 worth of rum I bought with the money I saved but that'd just be bragging.
Embrace the waste process. A real man would train his wife to clean this mess up.
Enjoy, Mike
http://www.homehardware.ca/en/rec/index.htm/Plumbing-Electrical/Plumbing/Waterworks/Fittings/Abs/1-1-2-Automatic-Black-Drain-Vent/_/N-2pqfZ67l/Ne-67n/Ntk-All_EN/R-I3252125?Ntt=3252125
Thinking of building a home made Big Orange, but as per the concerns above with not allowing enough air in when pumping out, could install one of these in the contraption. Just letting the squirrel's in my head run around a bit.
See? Squirrels.......
