342 w/350 MAG Hill Marine prop update
figured I would start a fresh thread for future searches.
Had part of a day to play with the Hill Marine 4x4 20P props on my Bravo 3's. For reference, I changed from the Merc 22P props.
Acceleration: From idle speed to plane: drastically improved and very smooth. Almost no digging of the aft, very little bow rise. Tabs down/drives down. Very noticable acceleration while on plane too.
Planing: little to no drive trimming needed. Was able to stay on plane at ~21mph w/o tabs. Again, very responsive accelerating from 21-30 mph. Interesting the wake behind the boat from the props is smoother looking too. Speed vs rpm I found no loss from before. Still need to make a WOT run.
Coming off plane: 342 owners know of the swimplatform wash. I still have that but it is MUCH less. The aft does not dig in like it did before. Idle speed / no wake speed is good at ~5mph. With the less churn from the props I can even pick up the speed at bit too.
Docking: For the first time the boat will truely 'spin' on point. Low speed response improved. A definate win.
Engine sound: This was a big suprise. The engine noise at plane is WAY down. Easily have a normal voice conversation now. Obvioulsy working less hard. Sounds smooooth.
I'll add more info as I get it. Might be the best $ I spent on this baby. lol. All thanks to this forum or I would have never tried them. So +++ to the guys who posted on these this year!
Some VV mobile screen shots to follow.
previous my calcs were in the .8/.9 mpg range.
It's great to hear the props are working for you. I've been talking with another 342 owner in marina and he wanted to know the exact details of what/where to buy. I may send him your way BD.
I just finished over 400 miles in the last 17 days on my hill marine props and gotta say they are fantastic! My wife commented a couple times on the trip how much quieter it is and noticeably quicker getting on plane as well as a smoother ride. & over a 100 miles were in the ocean.
My 342 does have the 'older' transom that is stepped in further. I'd bet the newer ones might perform a bit better with the drives further back. Plus a bit more hull in the water.
the 22P was certainly a game changer, better low speed handling, much improved planing time from before, bit it still was work to get going with another 2-4 people. Still could not stay on plane below the 27/28mph range.
These 20P 4x4 are a radical improvement. Hopefully I'll hit right around 5,000 rpm at WOT.
This is very a interesting discussion to me. I have had many Rinkers from the smallest to the largest hulls. I have lost count of the props I have tried on different models. I don't remember ever getting significantly better performance from any prop swap unless changes in diameter, rake or cup were involved.
I did get rides with a bit less vibration and maybe a 1-2 mph top end increase by having SS props blueprinted.
Most of the time I got either squirrelly performance (like from the old high five props) or WOT RPM numbers that were bad for the engines. That is why I would load the boat I was testing to its normal/usual load then go right for WOT as IMO WOT tells it all.
Of course, I have had friends with cruisers DELIBERATELY "under prop" their boats (too high a pitch) to get better acceleration and a smoother ride. As we all know this will burn more gas and one has to be very careful to not exceed the RPMs at WOT with this configuration and over rev the engines.
My bigger concern with re-propping an engine is to create a situation via pitch, diameter, rake, cup or a combination of the aforementioned that places the engine WOT BELOW the engines specified WOT range, because as we know this creates lugging which is really harmful to the engine and drive train.
In your case it would be over revving that I would be looking for.
I will be very interested to see where your engine's WOTs end-up.
MT, a lot of 342s I've ridden on have problems getting on plane and then staying on plane. The big difference here is switching from 3x3 to 4x4. It has made a HUGE difference on my boat as well. I also wonder if I should have changed pitch just a bit more, but I think it is ok. Right now I'm getting 4600-4700 rpm switching from 22p to 21p (but 3x3 17.5dia AL to 4x4 18.5dia SS). Most boat manufacturer's go with one brand of props and the average prop that will be fine for the boat.
The B-III prop diameters, at least the Merc ones are all the same diameter. All you can vary is pitch.
Hope I can snag WOT numbers this weekend. I'd like a calm day so the waves are not a factor. I'm shooting for 5,000 rpm
The engines sound amazingly happy.
http://s201.photobucket.com/user/Black__Diamond/media/Video_Aug_26_4_27_46_PM.mp4.html
Video link, hard to quantify, just listen to how quiet it is.
Cruise at ~30 at 4k rpm.
Calling it a win.
