Dipping Bravo 3 to cool
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
We are taking our 342 north from Lake Erie up in to Michigan next month and I was just looking at the mileage. We decided to not do drive showers this winter due to mixed reviews on clogging, we get a lot of zebra muscles here and algae. We know that we should probably stop along the way to dip the drives so the question is how often and for how long? We will be traveling with one other B3 boat, a chapperal, and 3 v drive sea rays who will not be stopping to dip like us. That's fine with me, I can catch up. Most of our runs will be 40-50 miles so I'm thinking no dip needed there but we will have one or two 70-80 mile runs so I assume one dip stop half way at a minimum? A few minutes per dip or longer? Appreciate the input.
I ran almost 8 straight hours with a fuel stop included heading to Mackinaw Is last summer. 3.5-4 hrs at a crack crossing Lake Mich.
Key is the oil in the outdrive. Synthetic is best for higher running temps.
It gives the drives a rest too, but I guess the weak link in the system is me - not the drives.
video of performance coming soon
Watch "DRIVE SHOWERS" on YouTube
If I do them, I will be looking in to these showers. $67.00 each:
http://www.eddiemarine.com/shop/drive-accessories/drive-showers/drive-shower-bravo-alpha-rigid-right-hand
If you are getting a chalky white residue on the top of your drive (the top cap) that means it is getting hot. Also if (as Al says) your drive lube reservoir is hot to the touch.
IMO just "dipping" the drive for 10 minutes is less effective that stopping, and running the drive at idle 800rpm +/_ for 10 minutes or so because that not only submerges the drive but also circulates water throughout it better.
Also do remember that B lll drives have an awesome cooling cap - designed for high heat - particularly the X drives and XR drives.
IMO (like Al said) use high quality drive lube - which I always changed every year - and always monitor its level. I also checked its color and smell.
It also depends on the rpm you are spinning those babies at. If you are on a long cruise at an engine rpm of 3400 those drives will purr along all day.
That said, for the sake of cooling, I can think of no better way to cool the drive tower cap than with drive showers.
BTW - the drive showers I used were more for severe duty applications: high speed runs, long days of water skiing/tubing - but - not needed, IMO, for my twin engine B lll X drive cruisers.
