2006 FV 270 anyone remove or replace the searchlight?
luvinlife
                    Member Posts: 501 ✭✭✭
                    I know it's still a ways off before I can get to it here in New England but I am trying to get ideas. I posted a while back about my searchlight. It is the Jabsco stainless steel bullet shaped light. It woks somewhat but flops around underway and doesn't always rotate unless I fiddle with the remote. I tried emailing Harvey Marine who it seems repairs them but got no response. A direct replacement is over 900 deer, which is too much in my opinion. I don't drive the boat at night but do use it sometimes in coves when staying overnight. I have two questions. Has anyone just removed theirs and replace it with a small flag mast?  I could just buy a handheld searchlight. Are you left with holes in the bow rail that look bad?  Or has anyone tried the much less expensive wireless remote LED lights as a replacement?  The white plastic ones. Just a few hundred for those. Are they junk or will it suffice? Any input is welcome.
      Post edited by luvinlife on
get New or used one and it will
wire right in and can be used with old control
i spliced mine right at the bow
Yes, I try not to use mine very often either. It hinders your night vision drastically! It drives me crazy when boats have them on like their car headlights! I have a narrow, low-height bridge at my marina. That is really the only place I use it (to see water level - for fitting under, and to just see under it since my width is over 14 and the bridge width is 20).
Dirty, light looks great. Mine is same shape, but not LED.
I agree with you @Dream_Inn about people who own boats that use them as headlights. We see it more often than not on the river that I boat on. You can't tell if the boat is heading towards you or away from you. The other thing that we see is pontoons that have the downward facing multi-color water lights running up river with them on, cycling through all colors of the spectrum. They are so bright that it washes out the nav lights. Both drive me nuts.
basicallt it can be the bullet as model
or square plastic.
only difference is some models have high and low setting and some just use single filament bulb.
Note that all signal wires are already there regardless of what you go with. Jabsco will be easier to figure out since it’s color coded.
yes wires are ran thru the top bow rail.
https://www.walmart.com/ip/Stanley-Fatmax-Waterproof-LED-Spotlight/21708661?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227015754260&wl0=&wl1=g&wl2=c&wl3=40839780992&wl4=pla-78652803632&wl5=9016843&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=21708661&wl13=&veh=sem
i use my light when coming back from fireworks to my marina or coming back in the dark up Clinton river from the Clem.
i think it’s a common sense to carry a backup light of some sort.
party!!!!!!!
