will the hatch work/
rasbury
Member Posts: 8,979 ✭✭✭✭✭
When the electrical is disconnected from the motor will the hatch still work or is everything grounded through the motor?
Can't remember if the hatch is on the house circuit or crank battery. I think house. I know there was a ground block right beside the battery, tied to the negative terminal on my boat. So I'd think it should work.
In case it doesn't do you have the by-pass terminals (poles) on your 12V panel where your battery switch is?
so why not raise/ lower it manually?
When I connect a jump box to the hatch terminals, it will raise the hatch. If I reverse the leads, it does nothing.
disconnecting it and reconnecting
you will
probably have to tilt the hatch near 90 to lift the engine out.
Remember it will have to go forward then up
and out
