Revisiting the factory 2001 FV270 swim platform
thepriceisright
                    Member Posts: 92 ✭✭
                    One of the issues I found while researching this boat before buying it was some reports of issues with the factory swim platform ploughing. After one season with the boat, I'm pretty sure I have this issue. For example, here is a picture of my boat compared to the same boat with a swimplatforms.com platform:
I am pretty sure mine ploughs. I have the 496 engine, in great shape, with 3 blade 22p props. I can barely get into the 30s and my RPMs top out around 4k. It takes forever to get on plane, even with nothing in the holds, very little cargo, half fuel, and less than 500lbs of passengers.
Before ordering a new swim platform I'm considering simply having the factory one removed to see if it's the issue.
Thoughts?
Edit: Whoops, I have 22p props.
Thoughts?
Post edited by thepriceisright on
Call up hill marine, get a set of 22p (or maybe 20's, they will let you exchange for "free", 120 bucks to ship them back though) 4 blade props for 1100 bucks (or I think I saw someone here selling them) and then sell your factory ones for 750ish on ebay like I did.. it's a no brainier. If it doesn't work out at least you have much better props and can then keep going with the swim platform idea..
I went with the 20p's with a 383 and it's a dream..
Same conclusion, @J3ff and @Carsnmorellc ?
if all you could get was 30 mph and 4k =22p = fresh tuned =drive in good shape=props in good shape=bottom in good shape=with 24p=should be turning @ least 45/4800 and 40/44mph
i wouldn't think you would hit 30 with 20p and over rev
uneducated 02
You don't think I'd hit 30mph with 20p props? I thought each 2" of pitch is about +400 RPMs, which would get me into the normal top end range for my motor.
Would be nice to make it from Cleveland to Kelley's Island in 1.5 hours instead of 2 though.
My other theory, per the thread title, is the swim platform adding too much drag. It definitely drags down in the water while accelerating, and pulls up a mass of water under it while on plane.
So we're going to try the new props since they've already shipped and see what happens.
Here's the thing, say you get them and the mechanic is correct and you don't get any more, time to cash in that free (sorta, shipping was 75 or so when I looked up fedex smart post) exchange.
