Air intake on my 2004 Rinker 312
Hi
I recently bought a 2004 Rinker 312 here in Norway. It has two Yanmar 4LHA-STZP diesels with Bravo 2X.
These engines need a lot of air (up to 30 m3 per minute). I have only found two tiny air-intakes in the bottom of the rear bench, and I don`t believe they can supply sufficient air.
Any experiences from you regarding "opening up" for more air?
There is a blower venting OUT. On ther outside of the boat there are no vents..??
I`ll try to get pictures on my next trip to the boat.
No vents at the back or sides either...
Former owner was seriously ill for several years, but he wasn`t able to keep the boat the way he wanted. Lack of tcl. Engines have only 450 hrs after 14 years. Needs to be cleaned up, but everything works perfectly (even the blender). Rebuilt at import to 220V ( Norwegian standard). Now I`m cleaning the turbos, changeing exhaust and mixing bends. Orders from US as prices are more reasonable
Think I will open up rear bench on the "end", that is towards the entrance from the platform and put in a big vent there (below the dog), and then open up bottom of the bench into engine compartment. Shoult fix breathing problems. (for the engines, not me...) PS! Former owners wife....)
I bought my exhaustelbows from HDI Marine. Perfect and less than half the price in Norway.
This is the Norwegian net shop. I can assure you they ar not made in Norway (nobody could afford them in that case)
Calculating the air need I end up with approx 30 m3 air pr minute on 3000rpm
(Please correct me if I`m wrong) plus air for cooling the compartment. I have further calculated the area to approx 1500 sq cm. Meaning 30x50cm opening.
Still believe I will go on with my project on air-supply..
Sometimes i wonder why I judt didn`t buy an old car...
I should refrain from commenting when I have been drinking, which is something I do with monotonous regularity, unfortunately.
