Hey Rinker i redesigned your dash hnt hint hint. You may want to consider these ideas.
2
  • canaancanaan Member Posts: 22 ✭✭
    Hey @diggin2day1 - Love your upgraded dash.  Do you happen to have "before" pics?  Just curious how many gauges you eliminated with that VesselView.  Now that I got my new sweet steps in, I'm looking for a new project!
    Thanks Canaan... here you go:
    Wow.  I wish you lived nearby...I'd pay some coin to have somebody do this to my 342 helm.
    That was a fun/tedious winter project!!!
    I wish they made a vessel view product for Volvo
  • dwmackenziedwmackenzie Member Posts: 13 ✭✭
    Hey David, love this. Re: the glove box, I see that for sale on GLS but in plain white starboard. How did you get the wood grain finish?
    @dwmackenzie I just wrapped it with a vinyl wrap.  Same as the dash.  Then sprayed it with a satin clear poly to give it a little shine.
  • YYZRCYYZRC Member Posts: 5,470 ✭✭✭✭✭
    edited October 2019
    No need for new/digital senders.... I called mercruiser and spoke with Kim. This is the information he gave me and it worked like a charm:
    Fuel:
    3-pin Fuel tank Harness- part# 84-864218
    Huge 10 pin harness from helm, follow to the T section where branches off... (3 pin plug/2 wires labeled "fuel level" (A-blk/pink tracer ..... B-light blue/blk tracer) unplug current sender and plug in new harness
    Trim:
    Digital trim- orange/white (bullet plug)..... Analog (orange/light blue)... Unplug analog and plug in digital.
    @diggin2day1 I have the 84-864218 harness has ring connectors on one end and I assumed they attach to the fuel sender at the tank and the connector attached to the SmartCraft harness at the helm.  I'm very confused now!
    This is the harness I bought:
    Thanks!
  • LaReaLaRea Member, Moderator Posts: 8,072 mod
    That's the right part.  It attaches to a plug on top of the engine, not at the helm.  The engine's computer digitizes the signal and sends it out over the SmartCraft network.
    edited October 2019
    Thanks LaRea!  So the ring terminals are in fact going to the senders on the fuel tanks?
    And I assume I should connect this to the starboard engine since that is primary?
    Another question - not sure where the fuel level senders are on a 330/340; any reason why I can't just tap into the harness somewhere between the sender and the helm?
    Yup, the ring terminals go to the sender.  But I vaguely remember, maybe my senders had potted wires instead of screw terminals, so I had to cut and splice the wires.  In theory, you could do that anywhere in the circuit, if you can find the wires.
    But you should make the connection as close as possible to the sender.
    I've looked everywhere and cannot find the fuel connector - any tips?
    edited October 2019
    heres a few pictures of the plug where the new fuel harness wires plug in:
    The top pic shows a connector port that is unused, do I remove the connector from that port and connect it into the new fuel sender harness?  That looks like the distributor to me...
    Thanks!
  • IanIan Member Posts: 3,064 ✭✭✭✭✭
    Mine are top of engine, what color wires?
    Ok, I'm not crazy.  Merc says I need harness 8M0075945.  Will order it and report back.
    I briefly looked around and couldn't locate the sender wires from the tanks.  Any tips?
  • MissLee2005MissLee2005 Member Posts: 67 ✭✭
    My redesigned FV270 dash with VesselView 4:
    Looks awesome mate....am in the process of refurbishing the same...what’s the gadget on the left? And what connects to engine so you can monitor revs, temp etc....I have a Volvo diesel
    Am aiming for this...wrapped Cfibre👍
  • tazdeviltazdevil Member Posts: 45
    i would like to know how you made the pedestal for the vessel view
    I remember there was a whole topic that @diggin2day1 did on this.  He manufactured it himself.  Maybe he can post the link to it (I can't seem to find it).
    @MissLee2005 the gadget on the left is vesselview.  It has all the gauges digitally.
    Hi Guys... here’s the thread about how I built the vesselview mount: https://rinkerboats.vanillacommunities.com/discussion/4600/winter-upgrades/p1
    If you add this new wire harness to the sender for digital fuel read out, can you also leave the existing wire attached at the sender so the analog gage still works as well??
    I believe @LaRea has said you cannot.
    Right, you'd have to build a custom circuit to do it.
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    When I hooked up my smart craft to my Raymarine I thought of hooking up the fuel senders but the cheap analog senders are not accurate and after looking at what it was going to cost to replace the senders with quality ones I opted out. Every time I fill my tanks I enter 160 gallons into my fuel settings and let the smart craft take over. The only thing I have to remember is that my genny pulls from the port tank and the smart craft does not compute that consumsion. I love the system it really shows how one engine can be so different from the other
    That'll work, but it's preferable to keep humans out of the data chain.  We make mistakes now and then.
    @goalie59 I do the same thing.  I've thought about changing the cables several times but never wanted to lose the analog gauges (really just having them still in my dash not work).  Resetting it with full tanks work pretty well.
  • DarkHawkDarkHawk Member Posts: 6
    Nice post. I'm not handy with fiberglass but I may have to try this after looking over you post. Thanks again.
  • MojosBoatMojosBoat Member Posts: 102 ✭✭
    Looks great! May be a future project for our boat. Hate the factory gauges.
    ALL IN AGAIN, 410 FV Twin 8.1 H/O MPI, V-Drives ,
