I thought this was a BOAT owners forum, not an rv owners forum.
But BOAT means break out another thousand and I think that still applies to RVs
I dunno. When I needed a new fresh water pump for the water system in the boat I found the same pump on an RV site for $75 versus $100 on most of the boat sites. Maybe for RVs it's only Break Out Another Couple Hundred.
I have had my RV for 4 months now and I havent spent a dime on it
Yeah....who wants to vacation in a mobile home, might as well sit at the house.....and go to an RV park next to bubba who raises **** all hours of the night- no thanks.
It probably hasn't moved from your driveway. BTW, how much fuel do you put in your rig when you do take it out? That can't be cheap.
It rained pretty good Saturday so I guess that eliminates deck hardware and lights. I did have the canvas up so still could be window track screws. One problem I did notice especially when the boat is at the house. With the grade of the road, water would pool in between the helm seat and the foot rest area of the helm. The drain under the helm often gets leaves but the panel wet is higher than that. There is also a weird flange where the helm nonnecs the the floor by the foot rest. The pooled water would generally disappear. I sealed it with some clear silicone, water has pooled there from a rain and does not appear to be leaking. I did pull down the headboard until it is resolved.
Yes greg- that is true but the headiner for the midship sleeping is right under your feet when your at the helm...where your talking about is much lower...if I look through the inspection plate there is a flange that would catch a bunch of water right at that floor level. ...hard to explain.
also how is the cabin leak coming along
So will start planning some trips and outings...
