bring 342 back to life
191012141530
    Love the color should reflect nice with the water and sun. Keep up the good work.
    Wow it looks awesome!
  • GMSLITHOGMSLITHO Member Posts: 1,618 ✭✭✭✭
    Wow looks great .did you brush it
  • javhavjavhav Member Posts: 420 ✭✭✭
    @GMSLITHO no it was sprayed on 6 layers of polyurethane enamel and 3 layers of a special ceramic  hybrid clear coat
    Tried spraying once outdoors in a yard years ago there was just too much dust and stuff floating in the air ,wasn’t happy with the results
    I did think to myself, “he must have found some nice days with zero wind!”
    Yes I waited for a day with little wind and I used a fast reducer and paint accelerator to flash over quick so nothing would be able to stick there's a couple of nibs but nothing to crazy can be cut and buffed but I don't see a need
  • golfdoggolfdog Member Posts: 151 ✭✭✭
    You're doing a fantastic job with your boat.
    Yea a couple of small bumps you’ll never notice, such a big upgrade
    WOW nice job.  She's gonna be a pretty girl when you're done.
    Man! That's going to be one nice looking boat when its finished. Great work.
    Thanks you guys for the feedback I appreciate it I was a little hesitant on the color but turned out better than I expected
    Gorgeous! I've gotten great results with Awlgrip (brush and tip) but always end up with a few suicidal bugs smacking into it. Or sweat drips (on the deck).
  • rasburyrasbury Member Posts: 8,941 ✭✭✭✭✭
    looking very nice!
    @Dude_Himself lol yep there's a couple bugs in the mix
  • MarkBMarkB Member Posts: 4,007 ✭✭✭✭✭
    Nice color.
  • MojosBoatMojosBoat Member Posts: 102 ✭✭
    Javhav, that looks awesome! It is going to look great on the water.
    ALL IN AGAIN, 410 FV Twin 8.1 H/O MPI, V-Drives ,
    Waiting for the day
    Nice ... you build that dock?
  • cls10105cls10105 Member Posts: 389 ✭✭
    Javhav, what mount did you sue for your tv and how did you find a sturd spot to hold it. I like where you put it but i couldn't feel anything that would hold a tv in that spot
    cruising on 6. tw0s
    If you're putting the TV over the opening of the mid-berth, you will end up going through the fiberglass behind the vinyl, which is behind the lower dash at the helm.  If you take out a helm cup holder and reach down you'll find that there is fiberglass behind the starter switches etc.  That's roughly where you will have screws come through from the inside.  In my case I used a small TV mount that does not have an arm.  I drilled from the cabin through the vinyl and fiberglass.  Then had a helper hold the nut inside the gap behind the helm while I tightened from inside.  I used 2 1/4 bolts to hold the mount.  Worked like a champ.  But it's a major PIA to reach.
    @Stodge thanks man
    cruising on 6. tw0s
  • MargaritaGirl342MargaritaGirl342 Member Posts: 4
    Your work is fantastic! What refrigerator did you go with in the galley. I need to replace my old Tundra.
    @MargaritaGirl342 thanks for the feedback and  the fridge I don't remember but I can check tomorrow I know its 110v but I used the DC converter from the old fridge
    edited April 2019
    drives done motors ran getting close and to my surprise only one leak found loose power steering hose
    prepping top for paint  a little body work and alot of tape and tinfoil
  • aero3113aero3113 Member Posts: 9,767 ✭✭✭✭✭
    Awesome! What color are you going with for the top section?
    I replaced mine with a Vitrifrigo 4.2CU.  They make a fridge-only version which I went with.  They have normal (with freezer too).  It fit great.  The biggest headache is getting the old and new fridge in and out of the cabin.
    Going with a fleet white I can't stand the bone white gel coat just wanted something brighter
