Decal removal
aero3113
Member Posts: 8,815 ✭✭✭✭✭
I ordered two Whizzy Wheels to remove My faded top decal stripes, I don’t know if I’m going to reinstall the stripes or not. I was going to use a heat gun to help remove the old name on the transom but I think the wheel might work better. Any tips? Should be able to remove the stripe from the windshield forward with the shrink wrap on and the transom is fully accessible under the shrink wrap to remove the name.
Ill try my heat gun on the transom name, but I think the wheel will need to be used on part of the stripes that are faded and cracked.
Anyway, I took mine off with hair drier and WD-40 for glue. The more black that's missing like yours @aero3113, the more solvent needed and less of the heat. A little more time consuming.
Never used one of those wheels. I can imagine a pass with it might take the worst of the adhesive off. Then the solvent can clean up the rest. That wouldn’t be bad.
Also mine was the same. Window back was in pretty good shape. Don’t know why that was.
