Dry Joint Manifolds and Risers
aero3113
Posts: 9,816 ✭✭✭✭✭
My 330 has dry joint manifolds and risers, my 242 had wet joint. I’m curious if dry joint have a longer life span than wet joint or the same?
From what I can tell, my boat spent its entire life in the Mamaroneck area. I have the Seacore parts so I'm hoping the transoms are ok. I'm debating having the marina pull one of the risers to inspect.
On a half system only the engine is closed loop, the manifolds/risers see raw water.
Point being, your manifolds should never see salt so id imagine they would last the life expectancy of the motor.
