My new toy 2001 2859 diesel
PickleRick
Member Posts: 4,286 ✭✭✭✭✭
About 800 hrs. Doing a shake down run this weekend. Fingers crossed we will have a trouble free weekened on the lake.
So far the only thing i cannot get working is the spot light. Ill be filling the water tank and testing out the head and pressurized water tank tomorrow evening.
Will post more pics as i can.
Looks clean which diesel? I think I saw one with a 4.7 Cummins, I do love diesels.
Their reliability was questionable on boats over propped or neglected.
You guys are better than anyone on the BL forums! Ill take more pics as i clean. This boat has been sitting for a while so she has the typical sitting grime. I dont have time to wash and wax before a shake down launch. The admiral is happy i did fit the ac unit in the aft bedroom and we have room for a box fan to circulate it to the main cabin.
The po removed the rear mattress for storage. New gel memory mattress on order. This weekend my kid will get that room as he already has a small fold out mattress he uses in the aft berth of the 235
I've also ordered a macerator to tie into my waste pump out so i can drain the holding tank into the camp ground waste station
Anyone care to tell me what thay filter contraption is with the red hose? Im guessing filter for raw water pick up? The thru hull for the inlet hose us on the other side of the motor by the hot water heater.
When changing bravo oil. I drain with both plugs out and reservoir hose crimped. Then fill from bottom hole. Then install bottom plug then top plug. Then release reservoir crimp. Then remove top plug to burp the system, reinstall. Then fill reservoir to top.
Does that sound about right? No reservoir on my alpha.
Im also going to want to do the impeller on the raw water pump if that's a replaceable part like on an alpha or old volvo pents. I need to find a service manual for this engine. Finding and bravo service manual shouldnt be difficult.
here is your goal 😆😆
Ill never get this engine bay that clean lol. Where is the trim tab reservoir, batteries, the trim pump???
Im not sure if that hose is marine rated or not. Looks industrial to me.
In the pic the raw water pick up has a fitting/hose attachment on it to connect a garden hose. Before purchase i had him run it for a while. It has since been reconnected to the seacock.
For some reason i thought the bravo sucked water up through the foot like that of an alpha or old volvo penta.
Or a lighter more powerful om606 Mercedes i marinise.
Or the yanmar from a land crusier or bmw that i can use VP parts on.
Im also thinking about the genset. What does a 4 to 7k diesel genset weigh?
