My new toy 2001 2859 diesel
2
    mercury/tdi
  • PickleRickPickleRick Member Posts: 4,406 ✭✭✭✭✭
    I found a mercruiser issued factory service manual. I when i get the lake tomorrow ill be doing some reading.  It appears my only pick up is via the thru hull for the engine but ill look more closely tomorrow in the sunlight.  I got the pressurized water system done, some stocking of the boat and plenty of scrubbing.  She needs more scrubbing but shes got all shell get before next week.  I've never owned a boat that could fit so many tools. Ill take more pics as i get more cleaned.
    The admiral wants to remove all the monkey fir this winter.  That means fairing the walls/celing and resealing all the windows.....im wondering how much some replacement monkey fir or vinyl would run and how would in make it stick?
    No don’t think so
    After a bit of reading the bravo has to pull water for cooling.
    You probably have a Y before it cones in to the sea water pump like other bravo's
    Ok so chances are no damage done to the outdrive running out of gear with water fed to sea **** for a few min
    Give us a video tour of it..cant figure out how you have a rear quarters with the i/0 set up...looks like an interesting boat!
    edited July 2020
    Im not sure how to post a video. Going to launch in a few hours.  Been working since about 7am on it.   I'll look into posting a video.
    You can post the video to YouTube and then just post the link to it here.
    beautiful day on the lake.  Not enough power to get on plane. I need to verify 175 to 190 is acceptable operating temp.  Will keep at hull speeds untik i can inspect turbo veins and change fuel filters and air filter.
    Also the holding tank smells like 100 year old terds
    Is a jacosn(spp?) electric head supposed to hold water between flushes? This one rums dry.
    Also these obs electronics are almost useless
    The winlass and bow thruster are the greatest invention ever.
    Hopefully just fuel filters @PickleRick . Looks great!
    Thanks @aero3113
    She starts too easily to be compression issues.
    Im guessing im not building boost.
    ive not bathed the deck.  The kiddo loves all the space for jumping off.
  • J3ffJ3ff Member Posts: 4,245 ✭✭✭✭✭
    Looking good, love all the windows!!
    edited July 2020
    Thank you @J3ff.
    Off to the grave yard island (1800s) for the kiddo to "ghost investigate"
    Very cool!
    Looks great! You can do some serious cruising on that boat without having to worry as much about the weather forecast.
    Thanks guys. Now that im back at home with Wi-Fi ill try to get her uncluttered and a walk thru video taken.
    I got it up to about 21-22 knots thus morning and again this afternoon.  Temps stayed bellow 195/200
    Still sub 3000 rpms. I feel like she still has more power there.
    Stilll plan on some service work this week before launching this weekend.  Maybe some diesel kleen
    Some pics of the aft cabin.
    ive been busy. I've resealed the leaky windows.  They leaked terribly.
    New boost gauge reads 16psi at 2600 rpms.  Was at 23.xx mph, about the fastest ive been on the boat.  Im solo
     1/4 tank of water.  Holding tank maybe 1/4 tank.  Fuel half tank.
    Tiny tack is back ordered due to China resistors.  This will verify my tach accuracy.
    A similar boat, little heavier, the 288 with a 220 hp vm 4.2 test ran @same top speed wot.
    My hull marine prop has been ordered since 8/11
    18.25 iirc 16p big cow 4 blade.
    I tried a solas 19x16p aluminum and changed it immediately.  Ordered it trying to pick up speed and rpm at the shops recommendation.  Top speed with 2 was maybe 18 mph. Sadly no returns.  So now i have a near 400 buck prop to use as a door stop.
    edited August 2020
    Ron Hill prop installed.  Big cow.  18.75 iirc.  16p
    She's supposed to help lift the stern of heavy boats.  Due to design should net me a few rpm over my current prop and plane quicker.  Should also lower my crusing rpm and improve low speed handling.
    Rain or shine I'm launching this weekend.  Pending no sever thunder storms from the hurricane barreling towards the Gulf.
    I will review further after a good solo run.
    Stay safe
    Looking good!
  • Dream_InnDream_Inn Member, Moderator Posts: 7,979 mod
    I love my big cow props!  They sure like nice in that picture!
    After all the high praise you guys gave them om the bravo 3 I figured they were worth a try on my bravo 2.  It's a near 35 lbs prop
    Yes, I  have the same, different pitch, on my B2s as well. I shipped one back when I hit something and it came in at almost 40 lbs with weight of box.
    I keep forgetting you also have the b2s.
    Did you go from 3 blade to the big cows?
    Yes we did. 3 blade was stock
