Tell me how you big single screw guys get on plane using your trim tabs
PickleRick
Member Posts: 3,895 ✭✭✭✭✭
You guys with a 270 and the like, especially the early 2000s where the platfrom drug into the water when getting over the hump. Im more looking for tips from you small block guys.
I have a boat that weights in dry at sub 8000 lbs per factory but i have an 1100 lbs diesel. Im sure my boat comes closer to 10k.
I can get to about 22 knots (around 24mph) when the wind and lake is calm. Im cutting about 3000 rpms, maybe a little more. My rpm gauge is about as accurate as our rinker gauges as it likes to stick from time to time. Usually a tap tap gets her moving again.
When i launch the boat i trim the tabs to push the bow down fully. This also improves no wake and hull speed (6/7 knots) tracking as she wonders badly without the tabs trimmed down.
Without the tabs my bow goes sky high when accelerating. With them she seems to hit 18 knots(where she gets over the hump) pretty easily. It still takes a min or two but she is a diesel, mpgs>speed. Once up even at 20 knots any easing of the tabs will bring the bow higher and i lose speed.
My question is do you guys play with outdrive trim when crusing, set tabs? Whats your method?
Thanks ahead of time guys. Rinkers rule.
Boat is a 2001 bayliner 2859 for reference.
I easily get in plane in about 8 seconds with full fuel and water and 2 to 3 on board. I figure fully loaded I'm about 9500 lbs.
Im looking into this now. I may be able to move my secondary bank under my table or under the v berth.
Being that im hitting 3000 rpms plus i doubt I'm having perfomance issues other than a heavy boat. I cannot remember my prop specs off hand other than 17 pitch. Im pretty sure its 22 3/4 but 24 comes to mind too
boat test did a report few years back = i cant find
In order to help cure constant overheating issues, Rinker/Volvo switched my original prop to something smaller and placed 200 lbs of chain in my anchor locker to provide more bow weight. This has mostly cured the issues. Crazy that they wouldn't have properly designed things for an engine they offer for the boat.
I trim down and full tab at the start then bring the tabs up when on plane. I trim the drive back to where I normally run when on plane. Lastly, adjust left or right tab to balance the boat.
Used to help factory list.
I have 200 ft of chain already. Since i have bow thruster i already have huge cables running aft. Wont be hard to run a double bank forward. That's obviously winter work.
Adding a marine a.c. is first. Might happen before winter. Was previously under the v berth and will probably go back there. Might help solve the issue.
i found a pic @ wot
But you're right, this is 100% a crusing boat and could be very comforable with a.c. at the helm and a 100 hp inboard plus huge genset to run at hull speeds with all the creature comforts at your disposal.
Soon ill be rambling about the great loop
gave it to my daughter who put another 15/20k miles on it
sold it to a father n son in Michigan = 1800 they did a 5speed conversion
we turned our 15 sportwagon back in during dzlegate
its a great boat
i would have to do the 454 unless i had the dough to make it a tdi/370
outboards would be killer with all that engine room for gen/storage
not into the bulkhead doors
i looked at several
short comings for us = out door space / kitty pad = we are loungers not fishing
most have no generator
