@matti I saw your post about outdrive maintenance: Outdrives removed & realigned & new seal kit annually. Do you do this yourself or take it to a boat mechanic? Could you share the cost of this maintenance? What about the impeller? I did not realize outdrives had impellers just like an outboard. Do you change your impeller every few years?
I believe only the Alpha drives have impellers in the lower units
Is remove the drive for winter a climate related thing? I’ve literally never seen anyone do that here. Some people down here don’t even winterize them at all, but since we do see a few days in the winter with single digit temps, I do winterize mine.
Any water that got in the drive can freeze and do damage.
I usually leave the the drives on but this was my first season with the boat and will be removing them to inspect and check alignment, plus I think I might have to replace the starboard side U joints. If I drained the drives and saw some moisture they would be pulled for maintenance.
I was told that the marina where my boat was kept (originally from NY state not too far from @aero3113) removed the drives from every boat and hung them in a storage container for the winter. It was part of their winterizing process, perhaps due to salt water?
My marina on Long Island pulls the drives as part of winterizing. Over winter they change fluid and pressure test them. Keeps the techs busy during the slow season
I always pulled my drives, its the only ture tell of whats going on. Leaky bellows, upper seal,u joint, shift cable, test speedo clean the little hole. Nice to know problems in the fall so spring comes your ready to go.
I’ve seen people remove the hoses from the pump to the drives and dump antifreeze down them, but I’m not exaggerating when I say I’ve never once seen anyone here remove a drive for winterization. Weird.
The 246 has a built in swim platform the 232 has a bolt on platform. The 246 must be measured bow to the aft including the platform. The 232 is measured from bow to stern Not including the platform. Interior space of the 232 is larger than the 246. The engine compartment is smaller on the 232.
Yeah, but even with that being true, the 246 is 26' overall. What is the 232 with platform?
I've been on both boats quite a bit, and the 246 definitely is not smaller looking or feeling. The built-in platform is a very nice feature, especially if the 232 doesnt have the extended platform. The only thing I dont like about the 246 is lack of a pump out head, but thats in the cuddy version. Maybe the open bow has that option?
@JoeStang I have the pump out head on my 246 cuddy. I built my boat so I’m not sure if maybe that is why I was able to get it?
I havent seen one with that option, so I didnt know it was available. Thats good to know they could be ordered with the pump out option.
Mine get removed and stored indoors. I think they do it for 2 reasons. #1 for winterization and #2 security reasons. They are worth a lot of money and pretty easy to steal................... Just say'n
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
