RAIN WATER LEAKS INTO AFT CABIN
We have a 280 express cruiser and the boat is on dry land. It doesn't matter if the cockpit cover is on the boat or the camper canvas....when it rains our aft cabin is wet. We used 5200 sealer around the cabin windows and around the screws on the rub rail but it still leaks. Pulled fridge in galley and water just meets the carpet behind fridge and goes as far down as the vinyl wall to the back of the aft cabin but mainly is wet on the outer side of the boat. CAN NOT FIND WHERE IT'S COMING FROM !! Does anyone have this problem and if so, where was the rain coming in from? As long as our Fisher Winter Canvas is on it's nice and dry.
Tiki, that is really a neat idea! A picture of the setup would really help visualize it if you have one.
Dejavu all over again! (welcome aboard)
I had the exact same problem on my 2008 280. Every time it rained the aft cabin would get wet near the back. The water was coming in from a lack of proper silicone sealer application at the bolts that attach the arch to the hull. This was a well known problem on many 280's. To verify that is where the water is getting in, remove the speaker from the arch on the side of the boat that gets wet and look into the arch with a flashlight. You can see the bolts that hold the arch to the hull (I believe there are 3 on each side if I remember correctly). On my 280 I could see water dripping off the bolts when a helper sprayed water on the arch to hull area. To repair the leak, simply remove the nuts and washers from each bolt one at a time and apply a liberal amount of marine silicone sealer around each bolt, reinstall the washers and nuts and tighten appropriately. It is a simple fix that will only take a few minutes to do. According to Rinker, they also had a problem with a lack of sealer around the aft cabin window, but that wasn’t the case with the 280 I owned. Regardless, I would check the arch bolts first because they are easier to get to. To get to the window you have to remove the shelving and vinyl on the inside of the hull in the aft cabin. I hope this helps you find your leak.
I am re sealing hope that cures it.
Take the screws out from the inside, note there is one under the hinge that is hard to see. Then you have to cut the caulk line between the SS trim and the plastic part, it will pull out from inside. Then there are several screws you will see that hold the SS trim ring in place once you have it apart. I used a <i></i>very<i></i> gentle heat (flameless micro soldering tool) to heat the SS up the outside, this breaks the caulk from it so it comes out. I bet you will find the amount of caulk is surprizingly small. I used almost a 14oz tube of caulk per port window to reseal mine.
As an added tip: use blue painters tape and tape the SS trim to the hull before you take it out, then razor trim around the SS ring and leave the tape on the hull. You'll need this to get it back together all aligned easily as the hole and the trim ring are very loose fits.
Seems like my pantry/Galley(?) window is leaking so the mattress and floor in the aft cabin is soaking wet.
Tried to remove the window today, removed all(!) screws but could not move it.
What is the SS trim? Is it the stainless/aluminium window trim on the outside ?
Do i need to cut something from the outside before i can take the window inwards?
Any help/tricks in order to remove the window(without anything falling into the sea would be very appreciated
To get the trim ring off, be very careful, it easily bends. I used a small flameless butane soldering type iron to heat the trim ring, that will break the caulk seal. Before you remove it, tape over the ring with blue painters tape and then cut around the ring. Leave the tape on the hull; you need to do this to re-align it.
I used boat-life caulk, filled the trim ring with it, then reinstalled, this will ensure a seal.
Tried replying here 2 days ago, with a picture and more accurate description. When posting, it said that my post would need approval from a moderator (?)
My post is still not showing...
Are all post going thru moderators?
I'll try again.
First off, i have used the garden hose to ensure the water is coming from the window in the pantry(removed fridge and yes, this is clearly where it comes in.
The to the window removal in what i hope is the correct way.
- Remove screws from the inside.
- Go out.
-Tape SS Trim to hull
- Heat SS Trim/Cut the inside area where the SS trim is (picture with arrow)
-keep tape and remove SS Trim
-Find some more screws behind where SS Trim was
-Loosen above mentioned screws
-Go inside
-Remove window from inside
-Clean window and/remove all old caulk
-Clean hull from old caulk
-Reinsert window and insert plenty of caulk
-Tighten window with screws behind SS Trim and inside
-More caulk and mount SS Trim. Will be using Terostot 2759
Sooo.. if anyone could confirm is this is the correct way, that would be highly appreciated
I'm pretty new to the boating world and also marine expressions in English. so bear with me here
Cars are way easier to work on!
i did Rebed some screws in the rub rail that seemed to help
definitely going yo check the windows
i wonder what the delet would charge to pull and reseal all 4
Home port: Hammond Ind.
