I used the dipstick to drain the oil yesterday and only pulled out just under 3 litres per engine, same as last year. A mechanic said that's normal but the capacity is 4.25L so leaving approx 1 L of old oil in engine.
Anyone ever have an issue getting their oil filter off? A friend of mine is having a heck of a time getting his oil filter off. He is ready to replace the plate that it sits on. Everything that I have told him to try hasn’t worked.
I had this issue once, years ago. I ended up using the hammer and screwdriver method. I put edge of screwdriver at base of filter and tapped it with hammer into the CCW direction. It finally started to budge.
+3 for hammer and screwdriver method. That happened to me on both filters on my boat when I first bought it. I assume the last person to change the oil didn't lubricate the o ring.
Genuine Mercury & Mercruiser parts. Mercruiser Gas Engine Oil Capacity Chart
Oil filter pliers will work too, They are messy & will tear it all up. But generally work.
For boat I always take the band type filter wrench & the filter pliers for back-up.
