Started then died...
rasbury
Member Posts: 8,850 ✭✭✭✭✭
Finally was able to make it to the ramp today and I started the boat on the trailer in the water everything was fine pull it off the trailer park my trailer back to the boat and the engine head died which it had never done before and it would not restart turns over sounds like it wants to catch have recently done my rotor cap plugs wires I also just change the engine oil. I did do it at my house and not on the water and I checked the oil while at the boat in the water and it seems to be overfilled would that cause it to eventually shut down it did come up the temperature was not overheating some little perplexed also doing this by voice while I'm driving home sad
A. The easy one, it was over filled. This is the one you want
So I pulled the excess oil out and got it down within range and it the key hoping I'd flood it out enough to clean off the plugs....hit the key and it almost wants to start and then just sounds like not getting fuel. So, figured I'd pull the fuel water separator and see what was going on there...great plan until I spun it off and it slipped out of my hand and is now under the motor where I can't reach it...but it looked like from what spilled I could see beads of water.
So, I put a container under where the filter spins on and hit the key putting a little fuel in the container. Looks like about 10% of what came out is water! So the water would hit the bottom of the tank and I assume the fuel pick up is also at the bottom of the tank so hopefully it is not proportionate to what is in the tank...do I buy several filters and replace them as needed? I've never dealt with this before...once that filter gets a lot of water in it does it stop the fuel from flowing I assume? How the heck would i drain it?
So if I'm on the water and have been running can I change that filter if I need to? Will the fuel pressure go down on its own once the motor is cut? Would not want fuel shooting all over the place...is there anyway to safely relive that pressure you or anyone else know of?
Thanks all for the input. I talked with the shop where I store the boat- they said to get a 12v pump that would handle fuel- pop the fuel sender- tilt the boat and suck out as much water as you can. If what I'm trying does not work that will be my next option. Hard to tell how much water is there..
Either disconnect the fuel line at the engine and put the priming bulb there, or disconnect the fuel line at the pick-up tube on the tank and connect a chunk of 3/8" fuel line to a primer bulb and go to town.
Either way, in my opinion the hassle of pulling the sender is unnecessary and just introduces risk.
Once you get as much water as possible out of it put a couple bottles in your tank. It will make water burn.
Is your engine carbureted? If so then there really is no pressure to relieve.
