Rinker Rinker Fiesta 360 2005-2006 Random Topics
tricountytrailtricountytrail Member Posts: 258 ✭✭
Rinker 360 Topics lightly different layout and floorplan.
I have a 2005 Rinker Fiesta Vee 360 These are slightly different from the other versions Foldable radar arch, stern door on starboard side, Length 39' 4" Beam 12' 3" separate forward stateroom.
Fuel Tank Capacity (gal): 235 gallons
Water Tank Capacity (gal): 51 gallons
Waste 45 gal.
  • tricountytrailtricountytrail Member Posts: 258 ✭✭
    Looking for Snap in carpet for my 2005 Rinker Fiesta Vee 360.
    Wondering if anyone has any suggestions or pictures.
    edited June 2023
    I'm pretty sure your 360 is identical to my 2007 370.  In April 2021, I got carpets from snapincarpet.com using a template that I made.  They don't list the 360 or 370 in their catalog of templates, but maybe they could cut another set from my templates.  If you want to ask them, the order number was S7212.
  • YYZRCYYZRC Member Posts: 5,491 ✭✭✭✭✭
    Do you still have the original carpet? I bought some nice “Infinity Weave” and traced the original carpet onto it. Had a local carpet shop put binding on it and I’m super happy!
    I do not, I could make a template, but would love to find a precut one.
    I did this for about $400. I hated how everyone makes the flooring in 17 pieces. Mine is two.
  • echandler1971echandler1971 Member Posts: 244 ✭✭✭
    I've got an '05 360 as well. I have the original snap-in carpets and would love new ones. I also want to know what people have done for curtains on their cabin windows.
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
    Who did you go with?
    Dan of Steel
    I made it myself. Ordered a bulk roll from https://marinevinylfabric.com/ and traced the original carpets onto it. Cut it out and had a local canvas shop sew on Sunbrella binding.
    Just ordered my carpet making template and cutting hopefully this weekend.
    Have to do a final trim then get them bound and install snaps.
  • aero3113aero3113 Member Posts: 9,937 ✭✭✭✭✭
    Nice job @tricountytrail 👍🏻⚓️
    Looking for rear seat cockpit filler cushions or even info or part numbers, Rinker Fiesta Vee 360. Pics are for example.
    My 360 with 3 cover options.
    Boat is hauled and ready for the winter projects.
    That's a lotta boat to put on a 2-axel trailer!
    It is a hostar rated transport trail trailer all hydraulic. I believe 30,000 lbs
    Anyone have any autopilot install experience? I am wondering what type of actuator I would need with twin mercruiser i/os?  Would it use its own steering pump or the existing one? I have the Simrad plotter wondering what else I need?
    edited November 2024
    https://rinkerboats.vanillacommunities.com/discussion/6500/autopilot-installation-on-370
    I use the GO12 with a NAC-2, Precision 9 compass and an Octopus Type R drive.
    Don’t buy the Octopus rudder sensor, it is garbage. Get the Simrad.
    I mounted the NAC-2 on the bulkhead and the Octopus between the stringers.
    What he said.  The Octopus Type R is an electric actuator that attaches to the steering ram.  There's no connection to the hydraulics.  And if something breaks, you can easily disconnect the actuator by pulling one pin.  (I used them for about 15 years on two boats; only needed to disconnect it once.)
    So I'm beginning to research my autopilot/ then radar upgrades.
    I have to Simrad go9 now connected to my engines and a NMEA 2000 network with a smartcraft gateway which this forum was a great help setting up everything.
    I will use my current go9 for instrument data.
    Going to install a Simrad Nss16 Evo3s Chartplotter/Fishfinder Mfd with a bracket
    and use it to build my new system with newest hardware.
    Will need Auto pilot drive, rudder sensor, heading or precision compass, and eventually a Simrad halo 24 radar. any recommendations.
    edited May 5
    Last July boat "Debonair" was totaled by this tree.
    Love it!  Same year as the wrecked boat?
    Awesome! ⚓️
    Yes just different engine package AND a bow thruster!! which I never thought I needed until I got one!!!
  • Corral42Corral42 Member Posts: 68 ✭✭✭
    My buddy was removing his props on his 05 360 with Volvos. We noticed that the props are different from side to side. Anyone know what the correct set is?
    Volvo Penta DUOPROP  F5Front  3851465 5B pitch is xx.xx inches, and the diameter is 14.75 inches Stainless Steel 3 Blades Lefthand rotation
    Volvo Penta DUOPROP  F5REAR 3851475 5B pitch is 22.75 inches, and the diameter is 14.41 inches Stainless Steel 3 Blades Righthand rotation
    These are what are on my 2005 360 with
    Volvo Penta DPS-A OXi 1.78 Duoprop Outdrives (replaced 2014)?
