I just used some of my connectors as well to wire an electric lift to our clubs tug boat. It now has an up down switch to lift the center console to access the lower engine room area.
I spent a few hours rebuilding our guest head today. The waste line below the toilet was creased in half and would clog very easily, bad install at some point. Everything that is a maintenance part in that system is now replaced including all new waste line for that toilet.
I painted the lazarette lids gas shocks black again after sanding the surface rust and reinstalled with new stainless screws and nuts.
Found the cause of the hatch leak and fixed that over our bed in the v berth.
Yesterday we dropped off all the fly bridge seating and helm seat from the fly bridge and are having it all reupholstered at a local shop. We are getting two toned light tan and light sand color.
I have a few more maintenance items to get done like oil changes on the engines and also I need to finish wiring my cockpit and fly bridge speakers to the stereo and also the light controller.
We have our first club event in a couple weeks so I need to be all ready 😊.
I replaced cool fuel filters this morning. Port was a little dirtier than starboard but not bad. The little tab on the lower screen for the port side broke off when I tried to remove it, a 90 degree pick helped remove it after. Painted drives and replaced anodes also.
Just when I thought I was coming to an end with spring prep I just saw my Starboard circulating pump had a slight weep at the top weep hole. Not enough for a drip but it would come back when I dried it off. The descaling probably added to this but this circulating pump always looked suspicious to me. Glad I have a reason to replace it now. I’m going to do the port side as well. Has anyone done this job? Looks pretty straightforward. Hopefully the bolts don’t give me an issue.
Now that I think about it, the starboard engine would squeak when I started it every once in a while last season. I always thought it was the belt but must’ve been the circulating pump shaft bearing starting to fail. I spent about 45 minutes heating the bolts with a torch and putting some mouse milk on them, this should help when go to remove them.
I just ordered the flybridge flooring from Plasdeck out of Ohio. Great company to deal with, this is the same thing we did in the cockpit last year. I'm going to have about 15k just in the flybridge from the new canvas(2024), flooring and upholstery. I'll post some pictures end of next month when it's done.
Yesterday I ripped the old poop tank out. Fun stuff.
Changed the oil in both drives. No water in the old oil and no metal filings on the drain plugs so all good!
Also installed a new pickup for the cockpit AC.
Did you replace the waste take or just take out the old one? What was wrong with the old one?
I was worried taking out my waste lines and vacuflush tank to clean and replaced the lines but it was actually not bad. We stay on top of flushing out and treating the system.
Port
