Hot water and water heater
rasbury
Member Posts: 8,777 ✭✭✭✭✭
I recently replaced the faucet behind the helm seat which I don't belive caused my problem but mention it because it was replaced. It only has cold water. Or it used to. So I was out on the water after replacing it, don't recall why I turned it on but it was like boiling hot water. I did not try any of the others. Now that faucet barley has any washer pressure while all the rest work fine. I've never messed with the hot water heater but I see there are hoses that I guess circulate engine hot water to support hot water when not at dock? If the heater is internally falling apart internally can that super hot water make it into the system? I'm a little upset that i spent 70 bucks for that faucet that worked perfectly and now does not. I drained the heater from the valve here at home and water drained out- I guess I need to get it running and see but I'm not understanding at all what is happening...any thoughts?
Eventually the rust had everything smelling like pennies if you accidentally turned the hot water faucet on.
Install was easy. Installed with the push/pull disconnects to easily bypass the water heater for winterization.
I guess I did not check that as i just installed it, and I will certainly check that. I thought being a cold water only faucet it was built different than a hot somehow- thanks I will check. While that might a solve the issue, what would be the explanation for scalding water shooting out of that faucet? I am closed cooling..
Something oddly satisfying for that faucet working smoothly. New pump much more quiet as well..it has been 105/115 feels like here in central Florida.
As far as the water, I guess I need to check the connections- the helm faucet was again scalding hot. So, that was a minus but maybe an easy fix. My marine radio for some reason has stopped working...sigh. next is the radio , the marine radio, the compass and check the water heater- it does not appear to be leaking.
https://www.vikingcompass.com/daco.html
I bypass the water heater before running antifreeze through the rest of the system. I don't even put antifreeze in the holding tank, I drain it empty and leave the quick disconnect unhooked. I run antifreeze through the rest of the system using the disconnected tank inlet line stuffed into a tub of antifreeze. I then use compressed air to gently blow the system everything out if the system.
The only thing I do to my water heater is open the drain valve at the bottom. I leave it open all winter. We don't get down to 0 F but it does drop to single digit over night lows with day times not getting above freezing for several consecutive days once or twice each winter.
I'd think what works for me would be golden in Orlando where it's warm enough for troops of wild macaques to become an invasive species issue.
