1128129131133134136
  • aero3113aero3113 Member Posts: 9,651 ✭✭✭✭✭
    I was reading that water in the fuel could cause a lean condition as well. I did change the fuel filters but before I did the plugs. It’s possible that was causing the issue.
    I checked the two plugs that wear bad and they were both showing soot but all in tact no signs of burning up. I’m thinking that the injectors might be a little clogged. I bought some treatment, hopefully it will clear them up.
    I hooked up my scan tool and there were no faults. I did notice that there was no block pressure on the port engine. How could this be, wouldn’t it be overheating? Could the sensor be bad (where is it). The Starboard engine was reading block pressure at 34.0 PSI. I also noticed that the temp gauge for the port engine is off and reads higher than it should. The scan tool on the port side showed 154 when the gauge shows 175. The port side always ran a little higher but at least I know it’s reading high.
    edited August 2025
    One other thing I forgot to mention was that both engines showed fuel pressure at 2.1 psi at idle. I feel that’s impossible and they most likely wouldn’t run at 2.1 psi. Why would it show that??
  • YYZRCYYZRC Member Posts: 5,366 ✭✭✭✭✭
    The coolant pressure sensor is in the power steering cooler.
    Both engines show 100% power available at idle, I’m guessing that means all cylinders are firing.
    Spark advanced is showing 21.8 on port and 4.1 on starboard at idle. I know that’s a big difference but advance shouldn’t be checked at idle and will vary, correct?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,862 mod
    Your water pressure of 2.1 at idle is where it should be.  I see mine all the time on my VV.  On plane it is approximately 20psi.
    @Dream_Inn do you mean Fuel Pressure?
  • IanIan Member Posts: 3,018 ✭✭✭✭
    My engines run at 154 idled/warmed and around 160 on plane. Drop off and back to 154. VVM tells me. 5.0 MPI
    sorry, I now see you said fuel pressure.  I was talking water pressure.
  • oscar1oscar1 Member Posts: 803 ✭✭✭
    Had about a little over an hour run to the dock where we will be staying for the weekend. Couldn’t get the port engine over 4000 RPM’s. 4000 is what I usually cruise at so I figured I’ll troubleshoot once I arrive. I was going to replace the fuel filter but decided to check the cap. Sure enough, there was some corrosion on the terminals. Cleaned them up with some scotch brite. We’ll see how she performs on Sunday.
    Before
    After
    wow you cruiser at 4000 rpm!!!
    Always nice when you have spare parts on the boat!! ⚓️
  • mbnarneymbnarney Member Posts: 190 ✭✭✭
    I have been through 3 swing arm type fuel sending units. All 3 seem to hang at 3/4 tank which really didn't give me a lot of confidence in fuel in tank. I decided to go with a reed type and immediately it was spot on. It was 98 here, i don't know what it was down in the bilge but I think I let enough sweat  to start the bilge pump. I had the orientation for those bolts set for the swing arm but of course the new one wasn't the same. I also replaced the stern shower because it was old and yellowed.
    I replaced my water pump after it failed, it apparently lasted 10 years according to the manufacturer date. The new one is the same pump but it's significant quieter. This was so much easier than my 280 pump, that thing was jammed way in there on the firewall.
  • LaReaLaRea Member, Moderator Posts: 7,999 mod
    10 years!!  Congratulations ... I've never had one last longer than 3 years.  On my current boat cruising full-time, I've replaced two in two years.
    When I told my wife that it was 10 years she said that's not very long. But I know all the stories of them not lasting. I may buy a cheap one as a spare just in case we are at anchor and have an issue, I also changed the wires to quick disconnect for that reason as well.
  • grouch0jrgrouch0jr Member Posts: 135 ✭✭✭
    What kind of connecters did you use? Deutsch?
    edited August 2025
    I just used blade connectors I had in my collection on the boat. Male on positive female on negative. Nothing special but at least I can disconnect and replace of needed instead of cutting wires back again.
    I think mine is original. 2003. Replaced the filter glass (plastic) only.
    edited August 2025
    Got my Sea-Doo working again. I didn't fully connect the exhaust when I did all the work last year so it was causing an overheat in the exhaust where it mixes with water.
  • TonyG13TonyG13 Member Posts: 1,411 ✭✭✭✭
    grouch0jr said:
    I bought a big orange filter for my waste tank. I don't have good access to the tank, so today I built a bracket to surface mount the filter to the firewall.
    When you need to refill/rejuvenate the charcoal get this:
    https://www.amazon.com/dp/B01EJ454HG
    Been using it for the last four years. Same as the name brand at a fraction of the price.
    Well, I changed the gear lube in both drives yesterday and the oil in both motors and generator this morning. Was good timing before the afternoon rain today, which is perfect to watch college football
  • rasburyrasbury Member Posts: 8,856 ✭✭✭✭✭
    @Dream_Inn you are just an over achiever! I did get a new jabsco search light controller and engine hatch switch installed so I'm not sluming totally...
    Thanks @rasbury .  It’s actually fun doing it all with boat on the lift.  The plastic oil tubs float under the drives and I use a remote for the lift to keep the drives holding them as the gear lube drains out.  Takes a bit, but I do both at the same time.  Friday morning usually is good with less boat traffic which means no wake at all.
    Well, I began my cleaning for (winter).  Engine room is done.
    Last time I submitted a photo for an issue down there i rec'd less than supportive comments. Maybe it's a fl thing but I can't get it clean to start with.
  • FormulabenFormulaben Confirm Email, Member Posts: 195 ✭✭
    If I ever have to pull the engine I'll certainly paint the bilge, as mine looks rough when clean too. They used some kind of splatter to give it a texture/look with black splatter on off-white paint.  And while it might make a slightly dirty bilge look nicer, it just never looks clean at all.
