New Amplifier
grouch0jr
Member Posts: 192 ✭✭✭
My 342 currently has 2 amps, the Clarion XC6210 (radar arch speakers) and the APX480M (front/rear cockpit speakers, sub). I'm thinking about replacing both of those with a JL Audio XDM600/6, which is 600 watts over 6 channels:
https://www.crutchfield.com/p_13698684/JL-Audio-XDM600-6.html?tp=96419
Anybody have any experience with this, or recommendations?
2006 342EC - Twin Mercruiser 350 MAG MPI Horizons
Post edited by grouch0jr on
I am no expert, but I do have years of experience with audio. Rather than waste a cent of your money, I would consult a shop, and have your list of speakers you plan on using written down, so they have give you the NO BS answer.
I plan on bridging two of the channels for the sub (which the amp is capable of), then running my 6 cockpit speakers off of the other 4 channels. I'll probably run the fronts/rears in parallel and give the arch speakers their own channels. That's the way it's wired now. The speakers I'm looking at are 60W JL Audio.
I'm comfortable designing the system, I just don't know what kind of power level to aim for. I guess it's safe to assume that anything more than stock will be acceptble for normal listening.
Wetsounds also has a great reputation, unfortunately that's become very popular and no longer much cheaper than JL.
If two boats are battling over who's playing the loudest crappy country bro rap music next to each other, i cannot distinguish a quality difference between either brand.
https://www.crutchfield.com/p_867HTM6/Wet-Sounds-HTM-6.html?tp=96419
I like that they use the temrinal blocks, should make for an easier wiring job.
If I could do it over again, I'd probably just grab the MMR-25W for the transom since it's wireless.
https://www.crutchfield.com/S-RDesB74Yc5t/p_13699955/JL-Audio-MMR-25W.html
https://www.bluesea.com/products/5191/MRBF_Terminal_Fuse_Block_-_30_to_300A
Ras -- external amps almost always use a "remote on" wire from the head unit. Instead of putting a switch in a big cable that carries a ton of current, the remote wire flips a relay inside the amp to make or break the power connection.
Edit: I also looked at schematics for a 2004 342FV (found elsewhere in this forum), but it didn't show the Remote signal at all.
This wire is low amp, as @LaRea describes is just to kick on the internal relay to turn the amp on. Think of the small wire going from your starter switch to the starter solenoid. The big wires are doing all the work, the little one just tells them to start or stop
You could run it to a control panel and set up multiple amps as zones. With the flip of a switch cut/send music to wherever zone(s) you want.
Disney's Frozen hit "let it go" being sent to the head, and only the head when someone asks to use your bathroom. Just punishment for non boat people calling it a bathroom instead of head, it's proper nautical term.
I didn't cut the cable to length at the battery side, yet. I still want to see if I can find a way to terminate it at the battery breaker panel. I feel like that would be a much cleaner, factory-style install.
