New Amplifier
grouch0jrgrouch0jr Member Posts: 247 ✭✭✭
edited August 2025 in Rinker Photo Gallery
My 342 currently has 2 amps, the Clarion XC6210 (radar arch speakers) and the APX480M  (front/rear cockpit speakers, sub). I'm thinking about replacing both of those with a JL Audio XDM600/6, which is 600 watts over 6 channels:
https://www.crutchfield.com/p_13698684/JL-Audio-XDM600-6.html?tp=96419
Anybody have any experience with this, or recommendations?
  • Lake_BumLake_Bum Member Posts: 1,142 ✭✭✭✭
    JL Audio is a fantastic choice.  You cannot go wrong.  They are worth the money
  • grouch0jrgrouch0jr Member Posts: 247 ✭✭✭
    Does 600W sound like enough power? I just want to make sure I'll be able to hear music at cruise.
    Well that's a loaded question.  Are you going to run the subwoofer with it as well?  I haven't looked at the specific model of amp you mentioned.  Some have the ability to run a bridged channel for subwoofers, while providing multiple other channels for your other speakers.  Your amp choice, should depend on what speakers you plan on pushing with it.  And quality companies like JL are "true" watts.  You can find a ton of cheap amps, that claim to have 2000 or 3000 watts that are pure garbage.
    I am no expert, but I do have years of experience with audio.  Rather than waste a cent of your money, I would consult a shop, and have your list of speakers you plan on using written down, so they have give you the NO BS answer.
    Ha, I know that "enough power" is subjective.
    I plan on bridging two of the channels for the sub (which the amp is capable of), then running my 6 cockpit speakers off of the other 4 channels. I'll probably run the fronts/rears in parallel and give the arch speakers their own channels. That's the way it's wired now. The speakers I'm looking at are 60W JL Audio.
    I'm comfortable designing the system, I just don't know what kind of power level to aim for. I guess it's safe to assume that anything more than stock will be acceptble for normal listening.
  • PickleRickPickleRick Member Posts: 4,385 ✭✭✭✭✭
    edited August 2025
    Can you swing the 1000 watt marine amp?   This would allow you plenty of power for a pair of what I assume are free air subs plus your 6 other speakers without having to max out the amp.
    Wetsounds also has a great reputation, unfortunately that's become very popular and no longer much cheaper than JL.
    If two boats are battling over who's playing the loudest crappy country bro rap music next to each other, i cannot distinguish a quality difference between either brand.
    I've only got 1 sub, and don't plan on changing that. I could go for an 8 channel variant so each speaker has its own channel, and 2 channels bridged for the sub. I was looking at Wet Sounds as well... Their 6 channel amp is a bit more powerful and less expensive than the JL. Looks like the speakers im planning on wouldn't max it out:
    https://www.crutchfield.com/p_867HTM6/Wet-Sounds-HTM-6.html?tp=96419
    I like that they use the temrinal blocks, should make for an easier wiring job.
  • FormulabenFormulaben Confirm Email, Member Posts: 228 ✭✭✭
    I have that exact same amp.  It's been great and plenty loud for cabin/cockpit/lounge entertainment.  I went with all JL Audio on my upgrade: MM105 downstairs, MMR-40 at helm via NMEA2000, and MMR-20 at the transom.
    If I could do it over again, I'd probably just grab the MMR-25W for the transom since it's wireless.
    https://www.crutchfield.com/S-RDesB74Yc5t/p_13699955/JL-Audio-MMR-25W.html
    This is great info, thanks. How many speakers to you drive with the amp?
    2 in the cabin, 2 cockpit, and 2 aft lounge.  All were upgraded to new JL Audio speakers except the aft cabin was 10" wetsounds.  Cutting that hbigger hole was fun.
  • rasburyrasbury Member Posts: 8,984 ✭✭✭✭✭
    I just want to replace my head unit and listen to anything..that project is coming up. It has a hard wired remote and also an app I believe..
    I'm saving this project for one the boat is pulled. Any time spent working in that right now, would take away from time out in the water. We've still got great weather here in Philadelphia.
    edited December 2025
    After getting the boat pull I tore the interior apart and got my pull line ran from the engine compartment to the cubby under the bed where the amp will live. I measured a roughly 50' run each way from the batteries to the amp.
    I ended up buying the JL Audio XDM600/6. Considering the length of the run, at 600 watts I need a 1/0 AWG cable. I didn't really want to go any bigger than that. I also bought all new JL Audio M3-650X speakers with RGB lighting.
    This has been a fun project.
    I bought a 50 amp MRBF (based off the JL Audio specs) for powering the amp. Is it worth considering terminating my power cable at the aft breaker panel? The existing breaker is 60 amp. Or am I better off just connecting directly to the battery?
    I went direct to the battery using a fuse block like this one.
    https://www.bluesea.com/products/5191/MRBF_Terminal_Fuse_Block_-_30_to_300A
    With my no knowledge I would say no to the battery? Won't that cause a constant draw?
    Ras - the amp only draws current when it's turned on.  There is a separate wire from the head unit that turns the amp on and off.
    Correct. The existing wiring is actually kind of annoying, no way to turn it off without disconnecting the battery.
    This is exactly what I bought. Definitely easier to do it this way.
    LaRea, did you determinate the original power wiring at the breaker panel? I'm concerned about leaving that abandoned wire hot.
    Larea that's what I've understood the correct way- but don't the post after yours lean back to they are constant hot?
    On mine, the original power wiring was still in use (for the cabin amp).  I added a new cockpit amp with a power cable straight to the house battery.  It was located in the cockpit, just forward of the trash can.
    Ras -- external amps almost always use a "remote on" wire from the head unit.  Instead of putting a switch in a big cable that carries a ton of current, the remote wire flips a relay inside the amp to make or break the power connection.
    I finally pulled my old amps today. One thing that surprised me is that each amp had its own wire for the Remote signal, 2 blue wires coming out of the wire loom. They were also jumpered together. This makes me think one is coming from the stereo, and then the other is going somewhere else. Anyone have any insight on this?
    Edit: I also looked at schematics for a 2004 342FV (found elsewhere in this forum), but it didn't show the Remote signal at all.
    A single signal wire, spliced to make two different wires (one to each amp), coming from the head unit would be the correct set up.
    This wire is low amp, as @LaRea describes is just to kick on the internal relay to turn the amp on.  Think of the small wire going from your starter switch to the starter solenoid.  The big wires are doing all the work, the little one just tells them to start or stop
    I guess both wires could be coming from the head unit, I didn't pull the stereo to look at it. Just seems like a weird way to do it, but I've seen stranger things.
    There are other ways to wire it but coming directly from the head unit is the easiest way.   If you've ever purchased an aftermarket cd player head unit this wire is blue and was usually labeled "remote"
    You could run it to a control panel and set up multiple amps as zones.  With the flip of a switch cut/send music to wherever zone(s) you want.
    Disney's Frozen hit "let it go" being sent to the head, and only the head when someone asks to use your bathroom. Just punishment for non boat people calling it a bathroom instead of head, it's proper nautical term.
    LMAO!!! Dear God, I just might have to do that...
    grouch0jr said:
    I got the new amplifier installed today. Power cables are terminated at the house batteries and everything works as expected. I just have to tidy up with some cable management and this project will be complete.
    So you powered directly tovthe house battery with a fused wire?
    Correct. I fused with a blue sea systems MRBF directly at the battery.
    I didn't cut the cable to length at the battery side, yet. I still want to see if I can find a way to terminate it at the battery breaker panel. I feel like that would be a much cleaner, factory-style install.
