If I ever have to pull the engine I'll certainly paint the bilge, as mine looks rough when clean too. They used some kind of splatter to give it a texture/look with black splatter on off-white paint. And while it might make a slightly dirty bilge look nicer, it just never looks clean at all.
Mine is the same way. The splatter hides the grime, but also my hard with haha.
Sounds like most have had a good season. We are going to try to find somewhere (drive) over Christmas we can see snow! It was cooler today and made me yearn for some boat camping!
Yes...what motor in that truck? I'm trying to get going on some boating...Will at least have a few cool days ahead..
It's got the 6.7 Powerstroke. F350 King Ranch edition. I tend to go through lots of different hunting trucks, but my Tow rig stays put. It's an amazing truck!
We had a Mystic trip planned for the weekend but weather forecast changed that. Pulled a wave runner out, pulled a whaler out, and tied everything else down with extra lines
Rinker sold but still have other boats Eastern LI, NY
Nice truck- I sold fleet and commercial ford for over 30 years. Ford has had it's share of problems but for a work truck, the F series trucks just have not been beaten! I have an 06 F150 2 wheel drive and I lovecwatching mouths drop when it easily pulls it up the ramp. Now if I was going over mountains etc I would want that diesel also but for florida, I'm good.
Ours is outside heated. I've said it a few times the northern boaters are real boaters as you have a limited season and expensive haul out and storage. Indoor heated for what 5 months? That has to be a chunk! You all have your orher winter activities as well - we just sit in the heat. We had a super mild winter last year- its been a long while since a cold one.
These have been in the water since April of 2024, but they sit on a floating pwc dock with covers. I was busy last year end of summer, then just said whatever they can stay there for the winter.
Thursday she came out, power washed the bottom. Yesterday winterized, canvas down, cover on. Next Saturday she goes into hibernation with the scent of Irish Mist, Bounce and moisture gathering damp rid.
One day closer to launch….
What do you do with the Irish Mist and Bounce? Just leave it out?
The Irish Mist soap bars apparently are good to keep out anything that shouldn’t be in there so I spread a few around will the boxes open. In spring there was a nice scent and they were moist so sucked a bit of humidity out of the air. The Bounce sheets - I unload half a box all through the inside - same idea to keep the air smelling nice. Stuffing them in the through hulls keeps out visitors also.
The easy things to service yourself on the drive is cleaning out reservoirs and change gear lube as welll as prop removal and lube. I have my drives removed for alignment check as well as everything else (gimbal and grease) every March.
We used bio bombs in our bilge and also the equipment bay where the vacuflush tanks are. The smell wasn't bad to begin with however these things wiped out any remnants of odor and since it's a gas it flows everywhere and kills any organic smell. This kit only has one tablet so I broke it in half.
I also Winterize the port Engine and cleaned the bilge. Next up is replacing the water pump impellers. Starboard is going back to harden since it has a drip port I’ll change myself.
I didn't perform any work but i paid the bill for the oil change on both CAT engines. 14 gallons of oil total. And that didn't include the generator. Diesel engines do like their oil!
Former Boat: 2008 350 EC Current Boat: 2002 Silverton 410 Sport Bridge Greenwich Bay, Rhode Island
https://biobombs.com/products/vehicle-deodorization-kit
