1126127128129130132»
  • grouch0jrgrouch0jr Member Posts: 47 ✭✭
    If I ever have to pull the engine I'll certainly paint the bilge, as mine looks rough when clean too. They used some kind of splatter to give it a texture/look with black splatter on off-white paint.  And while it might make a slightly dirty bilge look nicer, it just never looks clean at all.
    Mine is the same way. The splatter hides the grime, but also my hard with haha.
    2006 342EC
  • Lake_BumLake_Bum Member Posts: 1,073 ✭✭✭✭
    Winterized and tucked away for the season 🥶
  • Dream_InnDream_Inn Member, Moderator Posts: 7,800 mod
    Great looking storage @Lake_Bum.  Nice truck for hauling too!
  • rasburyrasbury Member Posts: 8,688 ✭✭✭✭✭
    Yes...what motor in that truck? I'm trying to get going on some boating...Will at least have a few cool days ahead..
  • captkevincaptkevin Member Posts: 400 ✭✭✭
    We winterized a couple of weeks ago. Missed out on some nice weather but had too many commitments & no time for boating. Hopefully next year
    Well, I waxed and covered the boat yesterday.  She’s all put away a bit earlier this year.
    Sounds like most have had a good season. We are going to try to find somewhere (drive) over Christmas we can see snow! It was cooler today and made me yearn for some boat camping!
  • IanIan Member Posts: 2,973 ✭✭✭✭
    Completed pack up, filled her up and she’s ready to pull out Thursday and winterize Saturday. Sad day.
    It's got the 6.7 Powerstroke.  F350 King Ranch edition.  I tend to go through lots of different hunting trucks, but my Tow rig stays put.  It's an amazing truck!
  • Rich_Rich_ Member Posts: 247 ✭✭✭
    We had a Mystic trip planned for the weekend but weather forecast changed that. Pulled a wave runner out, pulled a whaler out, and tied everything else down with extra lines
    Nice truck- I sold fleet and commercial ford for over 30 years. Ford has had it's share of problems but for a work truck, the  F series trucks just have not been beaten! I have an 06 F150 2 wheel drive and I lovecwatching mouths drop when it easily pulls it up the ramp. Now if I was going over mountains etc I would want that diesel also but for florida, I'm good.
  • TonyG13TonyG13 Member Posts: 1,381 ✭✭✭✭
    Hauled out today for its winter nap. Not a spec of crud on the bottom! Now planning my off-season projects.
    Looks good Tony. Where do you have boat pulled out & stored?
    We are currently at Forest View. Inside, heated.
    Ours is outside heated. I've said it a few times the northern boaters are real boaters as you have a limited season and expensive haul out and storage. Indoor heated for what 5 months? That has to be a chunk! You all have your orher winter activities as well - we just sit in the heat. We had a super mild winter last year- its been a long while since a cold one.
  • Aqua_AuraAqua_Aura Member Posts: 2,689 ✭✭✭✭✭
    Pulle the Sea-Doos out of the water for the winter. These need some serious TLC cleaning over the winter.
    Ours never sits in the water overnight & we spend lots of time detailing. Can't imagine the dark hulls to keep clean.
    These have been in the water since April of 2024, but they sit on a floating pwc dock with covers. I was busy last year end of summer, then just said whatever they can stay there for the winter.
    Thursday she came out, power washed the bottom. Yesterday winterized, canvas down, cover on. Next Saturday she goes into hibernation with the scent of Irish Mist, Bounce and moisture gathering damp rid.
    One day closer to launch….
    What do you do with the Irish Mist and Bounce? Just leave it out?
    2006 342EC
    The Irish Mist soap bars apparently are good to keep out anything that shouldn’t be in there so I spread a few around will the boxes open. In spring there was a nice scent and they were moist so sucked a bit of humidity out of the air. The Bounce sheets - I unload half a box all through the inside - same idea to keep the air smelling nice. Stuffing them in the through hulls keeps out visitors also.
  • FormulabenFormulaben Confirm Email, Member Posts: 177 ✭✭
    Ian said:
    The Irish Mist soap bars apparently are good...
    We have a decision to make...and I know which one I'm drinking bringing.
    Bottle of Irish Mist liqueur
    Irish Spring body wash products
  • aero3113aero3113 Member Posts: 9,530 ✭✭✭✭✭
    Besides prepping the new manifolds and risers, I didn’t feel like installing them today so I drained and serviced the drives.
    What else did you do as part of your servicing? I'm preparing to do this for the first time next weekend...
    2006 342EC
    When I said service, it meant fill. This year I plan on pulling both drives to check U joints and engine alignment.
    The easy things to service yourself on the drive is cleaning out reservoirs and change gear lube as welll as prop removal and lube.  I have my drives removed for alignment check as well as everything else (gimbal and grease) every March.
