1130131132134136
  • grouch0jrgrouch0jr Member Posts: 135 ✭✭✭
    Continuing with my helm glow-up...
    My Faria depth gauge was not functioning, but It wasn't a big deal because I could just read the depth off of my Garmin. It was a bit inconvenient though because the Garmin is off to the side and it's not always easy to see the depth right away.
    So today I installed a Veratron VMH Flex 2" digital display. I also installed a NMEA2000 network to connect it to the Garmin.
    Now I should be able to see the depth much more clearly while cruising (specifically when standing up at the wheel). I'm pretty happy with the Veratron. You can add multiple pages of data, and navigate between them. You configure it with an app, and it uses NFC to write the config to the display, extremely simple to set up:.
    I'm also happy to have the NMEA2000 network set up. Hoping to get the engines networked in this winter.
  • aero3113aero3113 Member Posts: 9,651 ✭✭✭✭✭
    edited December 2025
    Very nice @grouch0jr
    Did it come with a transducer?
    The Garmin came with the transducer. The Veratron reads that info from the Garmin.
  • captkevincaptkevin Member Posts: 483 ✭✭✭
    Looks great
  • rasburyrasbury Member Posts: 8,856 ✭✭✭✭✭
    Yes, awesome....I wish I had the ability to understand what you're saying...but sounds awesome! I just struggle with understanding electronics set up.
  • LaReaLaRea Member, Moderator Posts: 7,999 mod
    Nice work.  Veratron is a company to watch.  They are putting out some innovative products ... trying to compete with Yacht Devices.
    It's actually a lot more simple than it sounds. The whole process was plug and play.
    So far I'm impressed, I'd definitely recommend them.
    Post edited by grouch0jr on
  • mbnarneymbnarney Member Posts: 190 ✭✭✭
    The marina I am at is shutting down. I found a dock on the Tarpon river so the boat is going from rack to water storage. Thought I would get the drive up to date with new bellows, trim rams and trim sensors. I didn't have time for OJT learning and I would probably just screw it up anyway so I hired a mechanic to do the work and he was agreeable to me going along and watching the process. The minute he pulled the drive about a quart of drive fluid poured out of the gimble. Bought a seal kit, when he pulled the upper unit apart he found a quarter inch groove in the shaft where it should seal . So now I have to buy a new shaft. This is all on a drive that was supposedly rebuilt by professionals . I probably don't have 50 hrs. on it.   I think every flim flam man in the country is in South Florida. This kind of stuff sure takes the joy out of boat ownership.
    At least you found now before a breakdown on the water
  • FormulabenFormulaben Confirm Email, Member Posts: 195 ✭✭
    This is no different than fraud, IMHO. I hope you go after them, even if it's just small claims.
    I have just tried to do anything myself because of this. I did have someone replace a shaft seal on the prop shaft and the coupler. I have pulled the motor myself and done a ton of repairs ( with all of your's help!) But the level of nut jobs, especialy for boats is overwhelming.
    @rasbury, I would have liked to do it myself. After the first round of being dupped finding someone I could trust was nerve wracking. After reading some of your exploits I just didn't feel like i had the skillset to accomplish the task and get the boat out of the Marina before it shuts down. I Think I have the right guy now. Time will tell but he sends pictures of all the problems and the parts pricing has been spot on and he doesn't mind me looking over his shoulder.
    @Formulaben , These characters are still on the run, convoluted ownership and a string of victims.
    @mbnarney sorry for your problems as well...I think it's kind of like auto repair- if you go to the dealer you typically have a team of mechanics that work together on their jobs with a service writer so you have some really experienced mechanics and then some new guys- but usually they have to be on the path for certification and certainly a non certified guy is not working on your transmission alone. They also get the TSB information quickly and they always have factory support.  When you go to the independent shops it's always going to be hit and miss. You can have some good guys, guys that think they are good and then some idiots. Where I store my boat he is to old to work on i/o motors at all- but really I have not had much motor issues really..
  • Rich_Rich_ Member Posts: 294 ✭✭✭
    Plucked the final one out today.
    Got humpty put back together. Ran it out and its running great. So far no problems. Moved to a dock on the Tarpon River about 15 minutes to the Intercoastal and another 15 to the cut. Just looking forward to using the boat more.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,862 mod
    edited January 3
    Well, I finally got around to rebuilding my spare Hardin seawater pump today.  Great winter project.  Thanks @LaRea it worked great! I did have a little difficulty putting the new seal back in (luckily I ordered a spare kit for the next time) and crushed after finally figuring out the old outer ring of the old bearings was still in there (looked like it should be there). Already ordered another seal to have a full spate kit.
    Ok, we have someone to send our pumps for rebuild...
  • YYZRCYYZRC Member Posts: 5,366 ✭✭✭✭✭
    Knocked the snow off her.
    Yikes! I am washing mine today, 80's next week!
  • earl1z19earl1z19 Member Posts: 367 ✭✭✭
    Sanded off all of the old bottom paint. Going back with Seahawk tuff stuff barrier coat and then topping off with Seahawk Cokote . Will be nice to have a fresh start
    @earl1z19 , your just an over achiever! Nice. I dream of having our boat indoors to tinker on...
    I tinker on mine outdoors! But indoors sure would be nice.
    Very lucky to have the boat indoors - its worth every penny! I am usually at the boat at least twice a week all winter long. My list of off season "repairs" is always long so having access is awesome
    edited January 5
    @earl1z19 can you wrench the stands enough to move the blocks just a bit?
    Post edited by YYZRC on
    @earl1z19 can you wrench the stands enough to move the bocks just a bit?
    Sure can. I moved each one to get the clean plastic underneath. I plan on moving them one at a time when painting. The trick is to do just 1 at a time. When the guys do this themselves they remove all but the rear 2 stands.
  • Pat310Pat310 Member Posts: 601 ✭✭✭
    @earl1z19 what did you use for dust control while sanding?  Looks spotless around the boat
    Made a tent out of plastic and taped it to a sheet of plastic that was under the boat.  also a shop vac connected to the sander
    Was thinking everything looked super clean
    One of the cooktop burners accidentally got turned on with a plastic cutting board sitting on the cooktop.  I was lucky to notice it just as the first whisps of smoke were starting.  Another minute or two and it would have been a real shitt-show.
    Northern boats do get a nice break..my poor boat bakes 365. Where i store, I use to have a "nice" huge oak tree that gave it some shade- but also cost a couple of antenas, bent up bimini poles...I say nice because if you have not experienced oak pollen in fl....
