1129130131132133135»
  • Lake_BumLake_Bum Member Posts: 1,104 ✭✭✭✭
    One of the cooktop burners accidentally got turned on with a plastic cutting board sitting on the cooktop.  I was lucky to notice it just as the first whisps of smoke were starting.  Another minute or two and it would have been a real shitt-show.
    Wow.....you did get lucky!  I bet that smelled GREAT hahaha.  Lucky catch!  A few years back here at Lake Powell, one of the massive Houseboats that is a time-share burned completely, and sunk.  There are 20 owners, so you never quite know what the previous guy was up to when you arrive for your week.  Well......when the current guy showed up, he started flipping switches, and an upstairs firepit switch was flipped, and there was a cover over the top of it.  It promptly started a fire, and spread quickly.  Poor design in the switch placement.  Anyways, it was in the slips, and they unhooked it and shoved it away from the docks. It could have setoff a chain reaction of fires!
  • captkevincaptkevin Member Posts: 471 ✭✭✭
    Good catch Larea
  • aero3113aero3113 Member Posts: 9,619 ✭✭✭✭✭
    Very lucky @LaRea !!
  • grouch0jrgrouch0jr Member Posts: 113 ✭✭
    Could've been a disaster! Good catch. Anything melted onto the cooktop?
    2006 342EC
  • LaReaLaRea Member, Moderator Posts: 7,974 mod
    edited January 6
    The cooktop cleaned up fine with a razor blade.  The only lasting damage is a nasty second-degree burn on my hand from a glob of molten plastic.  Not gonna share that photo!   :D
    Edit:  At least I caught it so it didn't damage the flooring!   Skin will grow back ...
  • rasburyrasbury Member Posts: 8,816 ✭✭✭✭✭
    Oh my! Fire on a boat scares the crap out of me. But that's why it's called an accident- thank goodness you caught it.
    edited January 10
    Today I got all of my old speakers pulled, and ran LED cable to all of the speaker locations. I feel like I had the whole boat torn apart.
    2006 342EC
    Looks like fun project. What kind of speakers are you going with ?
    Definitely a fun project. I'm learning a lot about the boat by getting all up in it.
    I bought JL Audio M3-650X speakers to replace everything up in the cockpit. I plan on doing the sub too, but haven't bought that yet. Over the holidays I installed a new amp to replace the two from the factory.
    2006 342EC
    Very nice- at least you had the old wires to pull the new wires through. My radio head is dead and I bought a new one to install. I also need to understand how my amp is wired. I have a current draw at the helm somewhere. Someone on another forum mentioned even with a trigger wire from the radio head to the amp to turn it on, it may stay partially energized. I did remove two connections on the back side of my battery selector from BAT 1 to com term so those connections would stop killing the battery. Seems to have worked.
    You could switch amp to a manual switch to manually control if you think that is the issue
    edited January 11
    Thanks captive kevin- - I have what ever it is on the helm isolated along with the mercathode (I can not find) and the draw is stoped. While  running i think the system can handle it. While charging if the bat switch is off, 0% draw on it.  I will sort it out- new stero head to install....
    Nice work.  It's always a "face palm" moment when you find wires on a boat that are twisted and wrapped with tape.
    Guessing previous owner considered them selves handy but wasn't. Nice improvement
    Nice work @grouch0jr
    Reminds me of how my 330 was when I bought it. All the courtesy cockpit lights had the wires twisted and duct tape was used. The best was how they spliced the VHF antenna. What’s scary is that I don’t think the previous owner did this, it was who he hired….
    All replaced and done right now!
    Yikes
    Effing hilarious!  Probably the same boater who gripes because marinas never answer him on the radio.
    That's an impressive level of incompetence
    2006 342EC
    Hey! Someone taking pictures of my boat?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,843 mod
    I meant to post this on Tuesday, two days after the storm, the boat looked pretty good.   I had added some additional framework on Friday before the storm.  Not sure why after 13 winters of use, but felt better about not getting to it for a few days.
    I think with the wind, a lot of snow blew off before the sleet and ice built up at the end.  Everything was sliding off just fine.
