Friend of mine in our marina had a just married couple taking pictures with their photographer on the bow of his 40 Formula SS. Bow was full of dirty shoe prints. It was probably the photographers idea, crazy what people do!
Latest project: Upgrading to a wifi-controlled dimmer system for the salon, galley and cockpit. It was much harder than I expected, but you guys know I like a challenge.
I replaced 17 light fixtures a couple years ago, but those lights are not dimmable (which is why they were so cheap). Those are going to the landfill. Nobody on the planet makes a dimmable puck light that fits the cutouts on my boat, so I had to get creative.
For each cutout, I had to install a spacer to reduce the diameter. The solution: buy PVC pipe caps from Home Depot, and drill out the middle with a hole saw. That insert gets screwed into the cutout, then the fixture pops right into the insert.
Here's a shot of the "fabrication facility" where I made the biggest mess. BTW that black work pad on the table was also the landing zone for the cutting board that melted on the cooktop yesterday!
Have I ever written here about how much I absolutely LOVE using DIN rail for electronics projects? If you're ever doing custom wiring and you have physical space for DIN rail, it simplifies everything. I used it when I rebuilt the controller for the swim platform, and again for this project. Rugged, cheap, and so easy for troubleshooting. The controller itself was $70, and all other parts including enclosure, maybe an extra $50.
I've worked with DIN rail a ton in my professional life. Simply one of the best ways to organize wiring. You'd also be surprised what can be mounted on DIN rail. Do they make marine rated DIN rail and components? I've seen DIN rail and terminal blocks corrode pretty badly in humid environments.
And to think I wouldn’t walk there with my shoes on…..
@grouch0jr - I'm relying on watertight enclosures for corrosion control. I don't know if they will last for the lifetime of the boat, but they should last a long time.
Originally, the swim platform pump had a plastic enclosure for the controller, but it wasn't protected from being stepped on. Eventually, after too many careless footsteps, the enclosure broke open and salt air basically wrecked it. I added a custom box to protect the pump and controller from foot traffic. Then I used DIN components to rebuild the controller.
Latest project: ... It was much harder than I expected...
Isn't it always that way?! I feel like it's quite rare the "that was easy" project happens to be easy. Years ago, I started a personal rule: take what you think it will cost, and how much time it will take, then DOUBLE the cost and TRIPLE the time...and yet I'm still underestimating my cost/time occasionally.
Anyway, this flag just went up in my shop a while ago...it so hard!
https://www.amazon.com/BECAUSE-Outdoor-Motivational-Inspirational-Banner/dp/B0BV9SYYFH?th=1
