Pic Of The Day
1…125126127129131
  • captkevincaptkevin Member Posts: 605 ✭✭✭
    That is crazy that the same thing happened 2 times.
    Crazy!  Impact with submerged object?
    I'm not sure that is an impact ... a single blade?  You'd think at the RPMs that there would be some damage to the other blades, if it was impact.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,965 mod
    Definitely not either time.
  • Rich_Rich_ Member Posts: 368 ✭✭✭
    Seems to me there a manufacturing problem. Guessing material has a hardness issue causing it to be brittle & crack.
    The material is annealed so they can machine it & once done they heat treat to get the desired hardness. Guessing problem is either material defect or heat treat problem or some combination of both.
  • aero3113aero3113 Member Posts: 10,041 ✭✭✭✭✭
    I saw this pic on FB and took a screenshot. Looks like he put an access panel in the platform. I guess you can utilize the space inside the platform and box it off. Hope it’s water tight!
  • raybo3raybo3 Administrator Posts: 5,622 admin
    Might be an access to clean his stern drive????????
    seems like a tripping hazard to me. Also to close to the out board he put in
  • rasburyrasbury Member Posts: 9,015 ✭✭✭✭✭
    That looks sweet!
  • goalie59goalie59 Member Posts: 357 ✭✭✭
    Thanks for sharing, I have always had an interest in the older lighthouses. There are some great ones.
    (I learned that the correct way to say it is "Tronno".)
    Tarana is also acceptable if you have a Yankee accent....😉
    My friend is working on a 65' wooden boat. We brought our boat down for the week to the marina he is at, Ilwaco Washington. This is our first outing since getting the boat buffed and waxed. It actually reflects the water now 😊
  • grouch0jrgrouch0jr Member Posts: 267 ✭✭✭
    That looks like quite the project
    Project is an understatement
    Yeah he has it in the shed for about 2 months then another month outside. He can dedicate all of his week to it so that helps.
  • RiverRunnerNBRiverRunnerNB Member Posts: 36 ✭✭
    I'll take the recently waxed boat. :)
    Best looking Bayliner i have ever seen
    Beards Hallow Ilwaco Washington
    I think i shared this story before...at an in water boat show at the daytona beach marina...i got up on a flybridge and sat in that seat, I swear something wiggled....
    I want to be like you when I grow up.
    very Nice
    Awesome!
    edited August 1
    Some weird yellow bird that isn't usually found in our area
    Isn't that Floridas tagline? Lots of weird animals that don't belong here.
