1136137138140142
  • Rich_Rich_ Posts: 339 ✭✭✭
    Launch day. A bit late in the season with all the craziness of spring but fired right up. Still need a good topside wash and wax (hopefully get crew there in next few days) but at least floating. Still have one waverunner to get in, but everything else is wet
  • RiverRunnerNBRiverRunnerNB Posts: 36 ✭✭
    edited July 4
    Been chasing a rich condition since last summer. Boat was slow to get on plane, had some black smoke in exhaust, burning fuel more quickly, and hard to start when hot. Removed and tested the engine coolant temp sensor, hoping that would be it. Test showed it was operating within limits, but I replaced anyway (not expensive), and kept it for a spare. Removed all 8 spark plugs and each one was pretty heavily sooted up. I was quite happy with that result as it should mean a global fueling issue rather than say a dead cylinder, or bad fuel injector, etc.
    I initially proceeded to soak and clean the old plugs and reuse, but then decided to buy some new ones and start fresh. Old ones cleaned up pretty well, so will keep them for spares.
    Next stop was to pull the fuel pressure regulator to check for debris clogging the screens. Apparently there was a service bulletin from Volvo Penta (P-23-7-3) sometime around 2012 addressing issues with paint inside the fuel pumps being "released" into the fuel system and clogging the fuel pressure regulator screens. The service bulletin recommends removing the screen filter and replace it with an E-clip.
    This sounds promising as it could account for the issues I've been having with the boat, unless, of course, the service bulletin fix had already be completed. So, with great anticipation, I removed the fuel pressure regulator and found this:
    For comparison, below is the filter screen after I cleaned it:
    Looks about 80% blocked. I think this may be the root of my problem. Hoping to splash the boat in the next week, so will report back then. I ordered the E clip to complete the fix as per the bulletin, but it is not arriving till late July, so I'm running the cleaned existing filter screen until then. Kinda sucks being so late to launch, but at least we have a long boating season where I live (I wish! I live on the east coast of Canada. Our boating season is about 2-3 months long).
    Just a note that I have owned the boat for 2 years. No issues with fueling till last summer. Still working my way thru the boat maintenance.
  • grouch0jrgrouch0jr Posts: 231 ✭✭✭
    Wow, looks like that needed to be done regardless. Good find.
  • aero3113aero3113 Posts: 9,807 ✭✭✭✭✭
    Good find!! ⚓️
  • YYZRCYYZRC Posts: 5,441 ✭✭✭✭✭
    Put a couple hours on the old girl this weekend. First time out, zero issues!
  • TonyG13TonyG13 Posts: 1,438 ✭✭✭✭
    Replaced a bunch of worn out Stayput fasteners...
    With a few spare parts laying around made an adaptor which converts my galley table into a dockside table...
    Love the multipurpose table
  • Aqua_AuraAqua_Aura Posts: 2,705 ✭✭✭✭✭
    The boat polisher came today for day 1 of 2. The boat looks like a mirror 😲. This shows the back done as hea moving forward.
    I finished installing my victron cerbo and cerbo touchscreen. Lots of wires strung around the engine room that need to get zipties.
    The finish is looking great! Are you using the smart shunts with the cerbo?
    edited July 9
    I have Epoch lithium batteries which have Victron comms built into their BMS so the batteries are directly networked into the cerbo via rj45 cable. This gives me exacta data on the batter status.
    I can also connect to the batteries via the epoch app.
  • captkevincaptkevin Posts: 559 ✭✭✭
    Nice fix thanks for sharing
    TonyG13 said:
    My 12 year old Rinker OEM installed Lenco Auto Glide trim tab controller system finally died after a few months of intermittent working. When it died, I had no trim control, not even manual mode.
    Looked to just do a swap out of the brains, leaving harnesses in place, etc., but since Lenco has been absorbed by Navico they discontinued the Auto Glide line and have introduced something called Pro Control. That system is not backwards compatible and even requires new trim tabs.
    I've got this on my upgrade wish-list! Please provide an update on how the auto mode performs.
    I cleaned both IAC valves today. Not sure if I had an issue but my Starboard engine took longer to start the other night. Cranked longer than normal. I did try to start the next day and there was no issue so I figured it could be a sticky IAC. Both looked dirty and both cleaned up nicely. These are before and after picks of the starboard IAC. You can see how sooty the plunger and shaft was in the first pic. Second pic all clean. ⚓️
    Also, my new starboard drive reservoir had a drip. I couldn’t tell if it’s coming from the wires or it’s possible I dripped some oil and it went down the backside to the wires. I cleaned everything up and sealed the wires. We’ll see what happens.
    I also ran my generator for the first time this season. Started right up and ran for about 2 minutes then shut down with a LOC error. Tried again and got a UU error. I had this happen last year also. I bled the fuel injector and no issues after that . Ran perfect.
    That’s great @grouch0jr ! 😂
  • raybo3raybo3 Posts: 5,614 admin
    That's awesome
    good stuff
    Just a follow up post now that I finally splashed the boat and tested it out.
    Wow! The boat works great - starts without hesitation, cold or hot, and most importantly it jumps up on plane. Feels like I dropped a whole new engine in there. Although I did several tune up items, pretty sure 90% of the improvement was due to cleaning out the clogged fuel pressure regulator screens.
    Can hardly wait to get out for a good run now that we're ship shape.
    Nice find @RiverRunnerNB !! ⚓️
    Actually got to use it. Last time I was actually out was 4th of July weekend. Since then we’ve been to the lake house, at soccer tournaments, been to St Thomas/John. Plan it to head out for the week Monday or Tuesday, maybe longer
  • rasburyrasbury Posts: 8,954 ✭✭✭✭✭
    So, how about what I want to do to the  boat? Health issues, retirement with a long list of projects are all doing better. Getting back to the boat getting pushed up on the list. . It's been so hot, even near the water has been unbearable. Feels like 115 with 100% humidity is tuff to get motivated plus being our rainy season...lots of lightning...should start to taperoff and get ready for some hurricanes!
    I'm posting here because I just can't seem to find a good site/YouTube for servicing my hubs. I put new bearings, seals,races on the trailer when I first brought it home (had never done that before) and my miles have been low- but it's time. I have one wheel I get 120 degrees off the hub while the others are generally 20 degrees less. I also had a bearing just fall apart on the driveway on that wheel.
    I've posted here a few times but I realize most of you do not trailer your boats- if anyone can pass along a site for trailer service a 5 year old will understand I'd appreciate it. I suppose after 10 years with low miles I probably should start pulling each wheel and replace the bearings and seals. Do you always replace the races with the bearings? Any devices for packing the bearings? Its such a mess to work with...cleaning out the hubs? With my new storage, it will be easier to pull the hubs and bring it all home. I'm only a few mikes from storage.
    Thanks for any thoughts. .I've looked on E traiker and YouTube...
  • Dream_InnDream_Inn Posts: 7,936 mod
    @rasbury I've helped my son over the years rebuild the 4 hubs on his trailer.  We even bought an entire hub assembly to keep as a spare in case it goes out when on road for easy swap out.  As for the race, you should change that any time you change out the bearings.  It is a mess to work with, but just have something gloves (I'm married to a nurse, so she brings home many of them) helps a lot.  Here's a site that is pretty decent information:
    Essential Guide to Trailer Hub and Bearing Maintenance: Protect Your Ride - The USA Trailer Store
    I'm surprised after 10 years that any of the hubs are still ok, especially with the salt water you dip it into.  Maybe start another topic on this.  I think there are plenty of people that know a lot about trailers.  Actually, if you want I can just move these two posts to another topic?
    Yes @Dream_Inn, if you would. I'm fresh water with a rare dip in the salt.  I'm also 5 miles from the ramp
    I will check out the site - I did do it before, lord only knows if I did it right. I sure remember it was a mess. As of the lugs, or most of them, were spinning so I was cutting off luggage nuts. How I made it from the Pensacola area to central Florida I have no idea...but I rebuilt  the brake cylinders (had no brakes on that trip) and replaced all the wiring (had no lights on that trip), looking back that was not a good move on my part. I've kept up with replacing tires and checking break operation since.
  • SimcoeRinker400SimcoeRinker400 Posts: 341 ✭✭✭
    Well, guys, I sold the 400 in search of a Formula 45 Yacht.  One thing I can say is that hull specs for the 400 is the same as the Formula PC line.  Picture of the 400 last day in the slip.  Also, I have a tonne of Logos to sell and about 10 boats' worth of letters.
    2015 Scarab 165G
    Laser Sailboat
    2002 Seadoo Explorer
    2023 Seadoo Spark Trixx x 2
    edited August 5
    Congrats @SimcoeRinker400
    Where is it going? Or is it staying on Simcoe?
