Next problem - wet carpet downstairs.
Found some wet carpet downstairs last week - used a spot carpet vacuum to try and dry it up and a heater... and I haven't gotten it completely dry yet, even after a week.. now it started raining yesterday and poured ALL night and day which seems to have led to this spot being soaked again (again used the vacuum).
If you don't know... the North East has had a drought - up until yesterday... so I'm trying to sort out where this might be coming from. There's a few factors to consider:
1. I have slept out on the boat once and I did notice the fresh water pump DOES kick on every 15 or 20 mins and it runs for 10 or so seconds rebuilding pressure.
2. I noticed the wet carpet right after I washed it for the first time.
3. I have looked under the sink to see if I can see any leaking water, I don't see anything.
4. After a week of trying to dry it, I noticed it very wet again today after it rained (and no mooring cover) for 12+ hours.
5. I have tried to avoid pressurizing the freshwater system, but there are times that I really need it.. so I will go hit the switch, do what I need to do and then let all the water run out..
I have searched this topic and found a few threads, but they were all closed/locked...
If the freshwater pump kicks on, obviously that seems to be where to start.. is there any known issue with the water lines on this boat? or would any of you have any suggestions on where to look? I can't see any seeping water or water droplets anywhere.
Did u pull the cabinet in bathroom and look at lines? Pulling the showhead out, pulls on the lines, loosening them. Mine leaked this spring. if your getting water in front bilge, look there.....could also run elsewhere, depending on water following hoses. I'd don't like the fittings at the taps, very weak imo, and easily loosened.
I also resealed rub rail, lots of spots missing sealer. And if no cover, what about storage bin behind front port seat? If its not sealed up, that will run right down there.
The red and blue pex lines as you know are your hot and cold to sink. In mine there are shut off valves, to the sink in the engine bay. in front of hot water heater, as a process on elimination, shut those two valves, see if pump stays off.
I Also agree with Belle, also resealed rub rail, lots of spots missing sealer. And if no cover, what about storage bin behind front port seat? If its not sealed up, that will run right down there.
Its just Lots of maintenance.
Will also check storage bin and rub rail..
However the storage been is wavy and the sealant absolutely has holes all over it.. I really hope this is it and not the water lines..don't want to have to deal with replacing water lines at all!
http://www.homedepot.com/p/SharkBite-PEX-Pipe-Cutter-U701A/202685929
http://www.homedepot.com/p/GripWerks-1-2-in-CPVC-Push-Fit-Ball-Valve-126-8-12-12/205815459
http://flairit.com/
Home port: Hammond Ind.
Had a similar issue on mine last September. Went downstairs after cruising the lake to a completely soaked carpet and water coming out of the locker(everything soaked).
While out cruising the cold water fitting under head sink literally unscrewed and emptied what was a full water tank, spraying the water up the wall and into the locker. It took a few minutes to figure it out as you have to pull the storage front off and be a contortionist to get to the fittings.
Plan to replace the faucet with one having a little taller spout, get rid of the crackerjack stock fittings used and replumb with real PEX fittings prior to launch. Going to check and replace all other fittings if necessary.
Also right now I have pink water in the fresh water tank as I haven't flushed it out and the carpet is not pink.. there doesn't seem to be any evidence of the window leaking, but there is DEF wet carpet down there in the same exact spot. SIGH!! Might have to just get to work on removing all the carpet as I want that gone anyway..
A few also found it to be the mounting screws at the windshield.
Yes, I figured it out, in fact the answer to ONE of my problems was in the first reply. The sink in the bathroom was where all the water was coming from that was showing up in the mid bilge. One of the lines had a leak in the connection. Replaced that and things were better on the STBD side of the boat...
The Port side which is what is pictured in the first post turned out to be the window above the galley sink. Not sure why everyone seems to have a problem with that one, but thats where it was coming from!!
has anyone just taped over certain parts of the boat to see if it's that part before tearing into things?
Going to have to solve this before living on it! May just pull the carpets out as well. Hate the shag look.
