Looking for Suggestions on Sea-Trialing a FV 270
Hello All,
I am new to the forum and am looking at a 2006 Rinker FV 270 for purchase. Hopefully, all will go well with the survey and the sea trial and I will officially be part of the club! I'm in the Chespeake Bay area and look forward to attending the Rinkervous this year. Anyway, I'm going to be having a sea trial on this vessel in the next week or so and I am looking for some guidance as to things to look for on the sea trial or be aware of that may be of particular interest to this model.
A little history about the boat, it is a 2006 with the engine reading 212 hours and the tach reading 365 hours. I am assuming that is because the tach counts when the ignition key is on the "on" position regardless if the engine is running. The suveyor hooked the engine up to a laptop and 212 is what the engine computer stated. That being said, it appears the boat has sat for most of it's life. After all it is 11 years old with only 212 hours on the engine. Not sure it that's a problem or not.
The boat does not have a generator but it does have controls on the panel to add one. Has A/C but not sure about heat, haven't had a chance to mess with it. Powered by the Volvo Penta 5.7. Any responses would be greatly appreciated.
Find out whatever you can about the boat's history. Was it stored in a wet slip, or on a lift? Was it stored on land every winter? Did it ever sit unused for an entire season? The answers will help you better understand the amount of corrosion.
Look for signs of neglect, such as corrosion, mildew, broken accessories that were never fixed, or a dirty engine room. As you suspect, a boat used only 20 hours per year could be a real problem (or it could be a real gem if maintained).
Good luck - keep us posted!
The 270 is a great size boat and very popular in our area (wouldn't surprise me if you are looking in my marina - if so, I may know the boat and could tell you more). Is the engine fresh water cooled or raw water cooled. In other words, does the engine have a heat exchanger so it runs antifreeze thru it? If it is raw water cooled, you should see if the owner has changed out the risers/exhaust manifolds. One could go about 10 years on the Chesapeake without changing them, but they would be due. At 10 years old, there is probably some maintenance that is due just because of age. Most engine hoses need to be checked for cracks, and hose clamps need to be changed. Not a huge deal, but you just need to note it.
Generator, not a big deal with that size boat. You can easily use a portable for the demands anchoring out.
Good luck! & glad to hear you are eyeing up the Rinkervous! would love to see you there & I'm sure you'd get some valuable info from all the Rinker owners.
A sitting boat could be worse than a well used boat.
A lot of things start ceasing up if they aren't used and maintained.
I'm glad you had a survey done ... what came out of that?
For the sea trial I'd be looking for at least the following (what comes to my head right now):
- check ALL fluid levels before you start engine
- engine start up time (trouble starting)?
- engine warm up time and temperature the thermostat settles at.
- shifting into gear easy?
- check all systems one by one (A/C, lights, windlass, radio, TV, power head or vacflush, navigational systems, etc).
- go out, put tabs down and open her up ... time to plane reasonable?
- steering smooth and does not vibrate?
- tilt drive. Still smoth?
- idle speed and check manouvarability. Does boat steer to one side preferentially?
- check ALL fluid levels when you are done and engine off, compare to start.
- what does the bilge look like?
- check through hull areas, any leaks?
Hope this helps.
Good Luck, if you purchase please be sure to post the pictures and you will find this forum both entertaining (Handy and Ray provide hours) and very informative. Me, I don't know much about anything but most of these guys know a lot about something and they are always helpful and many watch the forum pretty close so you don't go long without some advise or suggestion.
Good luck and keep us posted!
The hull checked out, zincs didn't look too bad but we are replacing them anyway.
The broker and owner are going to do a spring commission in the next few days and address any de-winterization issues before the survey. I will take everyone's comments and suggestions into consideration when I do the sea trial and let you know. I'll keep watching the board if anyone has anything else to add.
Thank you!
http://www.yachtdatabase.com/app/motorshow.jsp?locale=en_GB&id=Volvo+Penta+5.7OSi-DF
The one you're looking at sounds like it's at a worse starting off point than mine was... Find one that doesn't list and can be started at anytime. 29mph is slow for sure. I think mine cruises somewhere around 26/28, with 40 being tops..
