considering a 2004 410 fiesta vee
looking to use this boat along the mid Atlantic - NJ - Va VIA the ocean - can anyone tell me the pro's and con's of this boat?
Oh, boy, it really depends on how you want to use it. It is a very heavy boat and does burn a lot of fuel. I guess I need to ask what type of drives (I'm assuming B-3 with 496 engines). Everyone loves the full size fridge, until you anchor out all weekend and have to run the generator. Washer/Dryer (if it has it), is really quite small and empties waste water into same tank as head (so it can fill it quickly). Some of the seacocks are a little harder to access (under the aft cabin bedding), but not absolutely terrible. Compared to the 420 or 400, no seat at all on the swim platform. If it has a hardtop, that is a huge bonus.
For a 2004, there may be a lot of items that after years of use, need replaced (just with maintenance). For instance, transom plates. Is the hull colored? (or white?) A colored hull can definitely be more maintenance, but are beautiful.
I know another forum member that keeps his 400 boat in the NJ area and tends to replace his coupler often. He states it's due to the saltwater conditions that eats it up.
The larger Rinkers are all a great boat for the value, especially used.
As for handling seas, they are heavy boats with a decent size beam. You'll be in good shape in most normal Atlantic conditions. When they get above 5' and short wave periods, very few boats are fun in those conditions.
Those 410's are nice. Definitely what i would be looking at if i weren't set on a flybridge and more beam. I may be fire sailing my 360 at the end of the season if you decide to go smaller.
I get 0.7- 1.0mpg. Mostly hangs between .7-.8 at a cruise speed of 32mph. The 420 and 410 both burn a bit more. I guess it's strange, but yes now that I think about it, every 410 I've seen has V-drives. And yet the 420's are different. Why the difference @alswagg ? The 420 and 410 are the same hull, correct? Just a different swim platform.
diesel are easily predictable at a given RPM they will alway use same GPH please see cummins chart at full trotle 3060RPM QSB use 20.1 GPH each or 40.2 GPH for twin if we say max speed WOT 34 mph this mean .87 mpg. and we all know full trolle is the worst MPG you could do. in fact to do .6mpg it would mean the boat max speed 24 mph at full trottle very unlikely
https://www.sbmar.com/cummins-marine-diesel-performance-curves/
My 400 with stern drive and gas gets 0.8mpg on average at a speed of 28kts. Sometimes 0.9mpg and really perfect conditions I've seen 1.0mpg.
