Kohler 5ECD Generator
aero3113
Member Posts: 10,107 ✭✭✭✭✭
What type oil and coolant are you guys using in your generator? Same oil as engines?
For the coolant, just a quality 50/50 antifreeze mix works fine.
Just make sure it says HD(high detergent) on the bottle as pressure washer pumps use an ND(non detergent) and both can be found in the same section lawn equipment section.
If you dont see 30wt on the shelf at your local auto parts store ask them to check the back but there should at least be rotella 1 gallon 30wt out there.
StayCoolPumps SCP Maintenance Service Kit with Spark Plugs for Kohler Marine Generator Models 4EF 5E 6EF 7.3E https://www.amazon.com/dp/B01MY7R1IE/ref=cm_sw_r_cp_api_i_XZt1DbETVPXWV
