Hardin Marine stainless steel replacement for Merc seawater pump
LaRea
Member, Moderator Posts: 7,977 mod
Does anybody here have experience with this Hardin Marine replacement for the Mercruiser seawater pump:
With the OEM pump, once the inside of the pump body gets worn down, you have to replace the entire pump for $700. The Hardin product uses replaceable SS wear plates at either end of the impeller, so in theory the pump should last the life of the engine. You keep the existing rear pump housing, and just upgrade the front part. It uses the same impeller as the OEM pump.
The upgrade is $200 cheaper than replacing the entire pump. ($500 with pulley at hardin-marine.com or MichiganMotorz.com.) Plus, it's a darned fine-looking piece of gear.
It sounds similar, but the pump from Hardin is stainless steel, not composite.
The part has the appearance of a dress part, but the functionality of an upgraded design. I'm going to upgrade my stbd motor, and then if I like it, do the port side to match.
After 2-1/2 seasons and about 150 engine hours, I noticed water dripping from one of the pumps. Sure enough, the inner bearing seal had failed and allowed water into the bearings. I thought the pump was doomed, but Hardin sells a "deluxe" rebuild kit that includes bearings, seals and clips for an extra $26.
All you do is disassemble the pump, remove the bearings and seals, and install new ones. The rebuild took me about three hours (not including removing/reinstalling the pump), but I'm sure I could do it again in half that time.
Hardin offered to replace the parts for free. I declined because I didn't want to wait for shipping and inspection, but it's nice to know they stand behind the product. Their customer service was great.
Here's a shot of the two new bearings.
@LaRea all's well that ends well but my question is why the h*ll did they fail at that (young) age. It's nice that Hardin will send new parts - but - will they also pay for someone to R&R their parts that fail if the owner can't do the work, I ask rhetorically? IMO, far too early a fail...and downright incredible for 150 hours unless you're parking on sand bars for hours LOL.
What are the OEM Mercruisers failing at 5 years and 500 hours? A fail at 150 hours is IMO ridiculous, especially after all their hype - they need some re-engineering.
Plus, they do look really cool.
Looks like I found my answer on Hardin's website. It goes between the plate and the rear housing. http://www.hardin-marine.com/instructions/625-4102I.pdf
Anybody who ever has to remove a pulley -- definitely buy the OTC-7185 puller and OTC-7209 installer. The $70 you spend will be sooooooo worth it. If you try with any other type of puller, you can damage the pulley.
After 3+ seasons, I am still very happy with these pumps. Also, the chrome finish adds 5 horsepower per engine.
I used an automotive puller too. The problem is that when you pull on the outside of the pulley, the hub deforms and clamps down on the shaft. That's why it takes so much force. The OTC-7185 tool clamps onto the hub itself, so it won't deform.
http://www.harborfreight.com/pulley-remover-and-installer-set-40749.html
@Alswagg what do you use for servicing Hardin pumps?
