I also got the new throttle cables installed and finished the generator tune-up (anode, fuel filter, plugs, impeller). I also got the big orange filter in and some of the new canvas up.
Overall, a successful weekend (FINALLY!)
Any suggestions on how to get my B3 drive out of reverse? I was cleaning the throttle bodies and my admiral shifted into reverse without using neutral. Seems like it wants more force than reasonable to get back into neutral. I know you're not supposed to shift when not running...
Has anyone replaced the Vacuflush flush ball assembly? My ball doesn't return to the fully closed position and I suspect it's due to a bent shaft. Looks like the shafts are brass now.
@YYZRC I've replaced it a couple years ago. Pretty simple task, you just separate the toilet at the large clamp/band that goes around. It also gives an opportunity to really give the bowl a good cleaning. Also buy the rubber rings that the ball seal against.
@YYZRC Wow, not sure how that shaft would get bent. I do know somewhere it says when removing foot from flush petal, DON'T let it up easy, but rather slide it off quickly so it snaps back up. Mine started sealing better when I switched to that technique.
I'm not sure if it is bent or not, I've read that the old plastic shafts can deform over time. I assume my shaft is plastic, not brass [and I hope Rick doesn't get on this thread ]
Yep. Even with exchange they're a good deal in Canada. But usually I buy in USD and ship to my buddies place in FLA and bring them back with me. About half price for the magnesium I use.
Helm updates almost done. New VV7, dash panels, wheel, binnacle, compass, radio housing, bow thruster (soon), new speakers throughout cockpit. Panel for mounting iPad next weekend!
https://rinkerboats.vanillacommunities.com/discussion/5613/how-to-make-the-transom-locker-door-open-to-full-height-on-360-370
https://www.marinepartssource.com/water-pressure-regulator-44411-1045
https://www.greatlakesskipper.com/jabsco-boat-water-entry-regulator-44411-1045-45-psi-white
Another random question - is the waste outlet the same size as the fresh water fill?
I want to switch to this:
https://www.amazon.com/dp/B07FY72Z7Z/?coliid=I2JIUFTI3Z8EPW&colid=3L5SAYULEBG0&psc=1&ref_=lv_ov_lig_dp_it
I will try your technique!!
LEDs replacing halogen bulbs in pot lights
