14344464849133
  • Pat310Pat310 Member Posts: 596 ✭✭✭
    Re-caulked the rub rail today. Waiting for drives to be re-installed but marina tech crashed his car last weekend and launch pushed to next week🤬
  • PickleRickPickleRick Member Posts: 4,217 ✭✭✭✭✭
    edited May 2020
    I finished cleaning and waxing the transom. Checked all trailer lights.  Test fired the engine on muffs to check oil pressure, idle, shifting and charging systems. All looked good
     Playing the launch by ear. Shes getting a shake down run tomorrow evening or Saturday.  If she's leak free and runs like she did last fall we will stay until Sunday or Monday depending on weather.
  • IanIan Member Posts: 2,978 ✭✭✭✭
    I’m in! Spent the morning prep of lines and fenders, some ends needed the binding redone and some clean up till the travel lift came. In she went, started like it ran yesterday and no issues, no water flooding in - until suddenly she started bilging from the mid pump. Looked in engine room and water pouring in from “forward”, shot below and could see at sea cocks water water draining from above and into mid bilge area. WTF - what’s above? Hot water heater but it’s not even on yet nor water lines flushed..... Popped the cover and sure enough, water there - hose from heat exchanger had popped off and starboard engine pumping well. Shut her down and reattached and checked the other 2 clamps and all is good. Never thought to check these before.
    Spent the afternoon continuing cleaning and mopping up, Bimini up and MarineMat down, water systems and tank flushed and filled, head prepped and all surfaces wiped with color wipes. Oh - and went over all clamps in engine room, hadn’t quite got there yet but that was a sign.
    2 positive outcomes from this:
    a) added to startup to check HWS clamps
    b) I may have solved an issue that has puzzled me for a while where I was getting bilge water after a good run. Never knew why, never found a leak and ran once with hatch open at 30 (son driving) and could see it coming from forward and all I could think of was the AC intake and perhaps a leak in the hose somewhere and pressure from higher speed forcing it out. I am figuring this is where it was coming from and today it finally popped off.
    Overall, a good productive day!
    So over the winter i installed air horns and i have to say that is my new favorite toy. It sure gets peoples attention when you want it. Now i just have to get the dogs used to it.
    My list of what I did and video of a couple of coats of Poli-Glow...
  • aero3113aero3113 Member Posts: 9,556 ✭✭✭✭✭
    Looks really good @DanD2
    Now looking at your list I realized I forgot to change my water separator
    You can literally see your reflection 😂. I like where you @DanD2 have the grill. Gives me an idea of how to mount mine.
    What’s a Kris?
    Good vid DD2
  • Dream_InnDream_Inn Member, Moderator Posts: 7,804 mod
    You may want to wait until you go thru your first tank of gas.
    I just bought a brand new VG4 vacuflush generator.  For some reason, once again, mine started leaking pressure and pumping every now and then.  It was also requiring a smack to make the pump kick on!  After all the work and parts changing out over the winter, I sank over $1400 on a new one! it'll be going in today and finally done with that crap! (pun intended)
    mattie said:
    What’s a Kris?
    Good vid DD2
    Ummmmm....soon to be X
    Ohh noooo, my wife is a 'Kris' too. Hope it's not catching. That sucks DD2.
    buddy of mine with 3-ex's, told me, "next time I'm just gonna find a woman I hate & buy her a house."
    That’s funny @mattie
    Installed the new cockpit fridge in my 270
    Is it 12 volt  and 110
    Sweet! I wish my 270 had that console. They didn't start with those until mid way 2001 I beleive.
    edited May 2020
    Changed out my joker valve while the plumbing was still dry. Much easier and less messy. I've started changing them every year, I think it'll lead to fewer problems with the head over the year.
    Did some more cleaning, put some of the seat cushions in. Still waiting for my mechanic to install a new gimbal bearing and get the drive back on so they can launch me. Was supposed to be done last week but he hurt his back and was off work for a few days. He's in his late 60's and been working on boats for over 40 years. Bent up, half crippled but a brilliant guy. He actually took the time to stop in where I work the other day and apologised for not being able to get my boat done for the weekend. A class act. Snapped this pic while standing on my swim platform of this big Prowler being launched. The largest boat now in our marina. They had to bring in a haulage guy with hydraulic trailer because our marnina's hydraulic lift trailer is only rated for 12,000 LBS and I think this guy goes about 16,000. Nice old boat, the owner takes a month every year and cruises Georgian Bay.
    Cleaned my water strainer again. This is only from being out on the water Monday! I put a couple of pieces of a chlorine tab in, I’m thinking this if from what the chlorine killed off.
    This is a dumb question, but where do I find this on the boat? And what does the outer casing look like so I know what I'm looking for?
    @TonyG13 it should be mounted right on your galley water pump.
    I checked mine yesterday and no visible growth on the screen. Hopefully the chlorine killed everything and flushed it out.
    Thanks! I will look next visit.
    Relaxed!
  • YYZRCYYZRC Member Posts: 5,356 ✭✭✭✭✭
    Looking very chill!
  • javhavjavhav Member Posts: 420 ✭✭✭
    Finally in for memorial day cruise https://youtu.be/9wLkkix4UGg
    @aero3113 I remember those days!  Seemed like yesterday, but now my kids are 17 and 19.  Although every now and then one will snooze for the ride. :)
    I think i may have been the first person in recent history to have his windlass go out on him and didn't have to replace it. I have the old Lewmar 600 and when it failed i yanked it out and brought it home.  Turns out the nut came loose enough for the little rollers that go into the key slots came out.  So i ordered new ones and made some out of a 12 penny framing nail to get me by in the meanwhile.  It was nice to not have to spend the $800 on a new windlass. Good to have tools.
    Mine went out 3 years ago, I brought it to a motor shop and they replaced the brushes. Been working ever since.
    edited May 2020
    Finally in! New gimbal bearing and seal. No more chug chug noise. Have to stand the antenna and all round light up, install new tv antenna. Cushions and mattress go in Friday.
