Rinker 330/340 2008+ Random Topics
1…1314161819…27
  • goalie59goalie59 Member Posts: 357 ✭✭✭
    YYZRC, not that I am being nosey but I am also in Ontario and looking for a vessel view, did you purchase from a Merc dealer or buy on line, anyone
     that you found were offering any deals, thanks
    edited May 2020
    I got it on eBay from a guy in Australia.  I think it was around $1200 USD shipped.
    Spyderweb said:
    @YYZRC Wow, not sure how that shaft would get bent. I do know somewhere it says when removing foot from flush petal, DON'T let it up easy, but rather slide it off quickly so it snaps back up.  Mine started sealing better when I switched to that technique.
    It pains me to do it this way but it works!  Thanks for the tip, Spyder!
  • SpyderwebSpyderweb Member Posts: 963 ✭✭✭
    Yeah, I know what you mean.  Feels kinda uncouth.  But that's what the directions say to do.
    Installed two new power steering coolers today. What are you using for PS fluid, ATF? I have “quicksilver trim and power steering fluid” that says it can be used in place of ATF.
    @YYZRC ,I use the Quicksilver fluid also.
    Thanks!! What are you using for garbage bags for the built in “well to the center of the earth” bins?
    LoL! 13 gallon bags.
    Aero, are your wiper arms/wipers original?  PO of my boat messed up the wiper arms (drilled them) and the wiper blades are clearly wrong.  Could you please measure your wipers and arms when you get a chance?  Thank you!!
    I will, I’ll get that for you at some point today.
    Thank you!!
    edited May 2020
    The arm looks like 23.5” or 24” and the blade is 16” .
    Do you have straps on the back of your bimini?  I see two loops on the transom but mine has no straps.
    Yes, if I have no curtains up I have to use the straps to keep the Bimini tight.
    That makes sense.  Thanks!
    If the curtains are up on the arch and everything else is down I still don’t need the straps. Only if everything is off.
    edited May 2020
    Back to this crappy topic - do we have the 149 in our 330s?  I assume discharge side is determined when sitting on the throne?
    iPad is mounted on 1/4” starboard. I think it’s going to work well!
    Looks good. What's on the iPad, chart plotter software?
    I’m going to guess Navionics app , I swear by it, best app out there.
    Looks great @YYZRC
    @YYZRC as for the toilet, I never figured out the correct model.
    edited May 2020
    Well I swear by it to. I was just curious and wanted to see what he was using without me running an advertisement for navionics which is a great app for a low price and can be used on multiple devices with one login. Ok I'm done.
    Also maybe there is some other special software on there we don't know about. 🤔
    Navionics FTW!
    Aero, can you please share the details of your order for the windshield gasket?  I need to replace mine.  Thanks!
    edited May 2020
    Send an email to tms@taylormadesystems.com
    Tell them you need 25’ of
    41100024 . It should be $1.17 per foot plus tax, $10 handing fee plus shipping. They will send you a CC order form.
    Thanks!!!  Anything else I should order from TMS at the same time?
    Not that I know of
    edited May 2020
    Just measured the pooper and it’s a perfect match for 148/149
    Edit: I found the instruction manual and it confirms 148/149
    I need to replace the fresh and waste vents, they’re badly corroded. Thoughts on these?
