Doral 330se
1235
    made some progress over the weekend
    Didnt know you had that in you
    Looks great!
  • mattiemattie Member Posts: 1,323 ✭✭✭✭
    Chris there isn’t one beer can in any of those pics......I call fake news.
    Looks great. When engines look good, they run good!!!!  ;)
    I like how easily accessible your starters are!
    Looking good.  I thought about these motors today as I was out there in the cold degreasing and doing touch-up paint.  Black paint is nice because it hides problems, but it can never look as good as gloss red.
    Made some more progress today should be able to start the Starboard next weekend.
    Nice
  • Dream_InnDream_Inn Member, Moderator Posts: 7,979 mod
    edited January 2021
    Dam, that's looking really good!!
    I admire your mechanical capabilities.
    Nice
    Thanks
    That is awesome! This is like your 3rd boat rebuild, do you ever sleep?
    Just wow!!!!
    I am unfamiliar with cruiser drive systems. Is that hydraulic pump attached to the bellhousing?
    That is the transmission, the shaft comes though the transmission and bolts to the round piece. The motor sits in the boat with the front of the motor facing the transom.
    turned over the motor have no leaks so far will start next Saturday. New coils new plugs and new injectors.  She ready to go time to strip down she sister. Put 4 gallons of antifreeze  and need more.
    The Fram filter is just for start up and will change after 1st run.
    Can't wait to see it in the boat. I'm wondering about the access as I am noticing you have stuff on the flywheel side of the engine that I have on the front. Is that serpentine belt easy to access when it's in the boat or more importantly how easy is access for the impeller replacement?
    Plenty of room behind the motors. The hard part is the coupler is about 6 inches from the fire wall.
    Yep plenty of room for maintenance 😊
    I always thought something's just not right when those motors are in backwards.😁 looking good!
    edited February 2021
    Frist start up of Starboard motor went well now time take apart the port motor.
    https://youtu.be/mKZseIn_bW4
    Not a very good video but you get the idea. It was 12° out side at the time so the driveway turned it to ice.
    Nice @reneechris14 !! It’s great that you’re getting to run the engines before you install them.
    Awesome! I love the comment from the Admiral. "I don't know, YOU look!"  :D
    I am jeolous.  I get crap when i run a leaf blower in my garage.
    Glad I did there is a plug in the head that was never tightened.had to take the manifolds back off. No big deal they will have to come off for installation. It's the only way to fit between the motors to do the alignment.
    Sounds great!
