Rinker 350/360 2007+ Random Topics
1…2122242627…34
  • SimcoeRinker400SimcoeRinker400 Member Posts: 342 ✭✭✭
    Did my props they look like new :wink:
    2015 Scarab 165G
    Laser Sailboat
    2002 Seadoo Explorer
    2023 Seadoo Spark Trixx x 2
  • SpyderwebSpyderweb Member Posts: 960 ✭✭✭
    Did mine a couple of years ago.  Looked great.   After about a month in the water, they looked dull gray again.  Decided it wasn’t worth it for something nobody sees but me when I snorkel each week to wipe down the drives.
  • YYZRCYYZRC Member Posts: 5,535 ✭✭✭✭✭
    edited November 2022
    Agreed that the shine doesn’t last long @Spyderweb .  Saying that, it’s not exactly “work” to spray and rinse, so I can’t not do them at the end of each season. It’s the easiest boat cleaning task there is!
  • LaReaLaRea Member, Moderator Posts: 8,077 mod
    Prop cleaning is about fuel economy, not appearance.  Surface roughness = more fuel for the same amount of thrust.
    The only question is -- how much do you save?  If you drive a 600-foot cargo ship, there's plenty of data about cleaning props.  I've never seen any for rec boats like ours, but it's a "small effort, small gain" situation.
    Plus you get that gratifying launch day photo op.   :)
    These are mine after a power wash by marina., maybe not as shiny but good enough.
    Couple pics of mine a couple weeks ago
    That port trim ram anode is hurt, @Dream_Inn
    I'm jealous of how nice your drive stickers are; new ones are like $250/drive!  WTF?!
    Is this pic from last winter @Grahamu ?  No way there's that much ice on Simcoe already!?!
    Yeah, I guess after 5 years the anodes need replaced. LOL!  Not nearly as big of a concern on a lift.  I had ordered some new ones a few weeks ago.  I'll get them on over the winter.  I also need to do a little bottom paint touch up in the spring.
    @YYZRC do you spray the when on the drive?  Is there a concern with acid on the seals?
    @YYZRC, Yes January this year, they power wash and change drive oil when they can safely stand on the ice.
    I take the props off every fall.  Saying that, there are threads on here where people have cleaned the props while still installed (I think @Lake_Bum was one contributor).
    Great way to keep service dept busy in winter.
    The drives performed well this season, I only added maybe a 1/4 cup of oil.
    I take my props off annually for cleaning, then grease the splines before reinstalling.
    I also inspect the leading edges for nicks or burrs.  I learned that from a former SEAL commander.  He told me their practice was to drag a strip of silk across the leading edge of each blade.  If the silk snagged, the blade needed more work.  If it works for SEAL boats, it'll work for my Rinker!
  • raybo3raybo3 Administrator Posts: 5,620 admin
    @LaRea you can do the same thing with a Q-tip..... just say'n
    @raybo3 don't you think it's highly likely that @LaRea has copious amounts of silk at the ready?
    George Costanza Art Of Seduction Painting
  • Lake_BumLake_Bum Member Posts: 1,144 ✭✭✭✭
    I didn't have the greatest results.  And I never did remove them to do a full soaking.  It did work a little however!
    Shrink wrap day. Better late than never.
  • aero3113aero3113 Member Posts: 10,018 ✭✭✭✭✭
    Any damage to your canvas from shovel boy?
    Looks to be ok thankfully. Will give it a good look in the spring. Just cleaned it up and stacked it nicely (with sheets between layers) in the v-berth for winter.
  • kordokordo Member Posts: 251 ✭✭
    YYZRC, I see you standing on your hardtop with no problem.  Good to know.  Do you have an extra support post/pole at the front of it?  Thanks.
    @kordo no extra supports. It’s plenty strong as designed/mounted.
  • tricountytrailtricountytrail Member Posts: 260 ✭✭
    tricountytrail, what is your process?  Nice work.
    edited December 2022
    Quiet on here these days.
    I rebuilt both transom assemblies with new stainless steering pins and replaced the cracked gimbal ring. Will sell them in the spring.
    Also got some new stickers as @Dream_Inn had me all jealous.
    My boat had the old seawater pump housing back plates that were solid brass. They were scored pretty bad when I put new impellers in two years ago so I replaced with the new plastic back plates with the removable wear insert.
    Here's mine because its slow lol.
    Servicing my drives.
    Like my new home made lift?
