Waeco fridge only works on DC
Dream_Inn
Member, Moderator Posts: 7,564 mod
So, I just got back from 10 days on the boat. Noticed that when we plugged into shore power the cockpit fridge didn’t work. So I decided to turn the AC breaker off and it began working well again. I figured that was fine for now as when I’m on AC my battery charger is on. My plan is to pull it out this Friday and check the fuses and connections on it. I’m thinking maybe a switch isn’t working when I change input power sources. I’ll get my meter out and check ac input power as well. Anyone have any thoughts?
If I remember right, @Cableguy Greg had a similar problem a while back?
I know other have replaced theirs (mine is Waeco CR1065). What did you replace it with? I will probably go with something at Annapolis cruisair since they are right down the road.
https://rinkerboats.vanillacommunities.com/discussion/13705/crx-1065-cockpit-refrigerator
Aero, is that fridge much different than what you had?
Freezer size seems to be the same as before.
