What are the “rules of using the head” once a brand new tank is installed (and I’m guessing all new waste hoses as well?)… will there be a sign posted for what is and is not acceptable depositing? I think I’d just lock the door and no let anyone in for at least one boating season. I mean it’s like having a brand new boat for crying out loud.
@YYZRC what’s nice about the vent is that you can pull it out and the rubber grommet then stick a hose in and spray down the sides. Really helps when the level sensors get gummed up (put the vent near your sensors). At the end of the season I put a long PVC pipe in with a scraper on to end to get everything that’s stuck on the bottom loose, fill it up with clean water and flush it out for the winter.
It is about 600 lbs and the lift is about another 100. It isn’t good obviously but she still gets up on plane. The bottom paint made all the difference.
WoW! I don’t remember paying that much. I think I was able to get mine pretty cheap from Great Lake Skipper . I had to replace my port sender a couple years ago.
https://www.marineoutfitters.ca/index.cfm?category=10005%7C11850&product=78042701&code=811577010305
Put in a tank saver relief valve while you’re at it!
https://marinesan.com/tanksaver-relief-valve/?gad_source=1&gbraid=0AAAAADMyfloSuT_M7BOxl0BR1DWIx1aGE&gclid=CjwKCAiAkc28BhB0EiwAM001Tb__4RTv0s-QkZTjmG6Zw1Yn-2mRCDoj9bS5slSQegZr0es9rk1N0xoCP8sQAvD_BwE
“If you ever drop your keys into a river of molten lava, let'em go...because man, they're gone!”
― Jack Handy
