Pulled her, have a project to work on….
1…457910
  • aero3113aero3113 Member Posts: 10,032 ✭✭✭✭✭
    I picked up the new heads today and painted them. Hopefully installing them tomorrow.
    When I was wiping them down before painting, I noticed a hole that I didn’t remember. I looked back at pictures and sure enough it had a plug in it. I looked in my fitting drawer and luckily I had two!
    I noticed I tapped off the exhaust gasket area wrong. So painted the area that needed paint.
    Beautiful!
    I cleaned the paint off of the mating surface for the head bolts by the exhaust ports.
    Beautiful!
    Thanks @LaRea ! ⚓️
  • YYZRCYYZRC Member Posts: 5,542 ✭✭✭✭✭
    I hope mine look that good when done…
    @YYZRC , how did your cylinders look? Are you rebuilding the motors or cleaning up?
  • captkevincaptkevin Member Posts: 605 ✭✭✭
    New heads look amazing
    Full rebuild for both  :#
    Nice!! 👍🏻
    Bored 030 over, the shop claims I will pick up a few HP.
    Nice!
    edited September 23
  • rasburyrasbury Member Posts: 9,010 ✭✭✭✭✭
    I don't understand. I'd quit poking holes with a screwdriver if that caused the problem. Just kidding...but why did the metal fail to a screwdriver?
    Same reason there are so many muffler shops are around tampa and Daytona....rust!!!
    My 06 f 150 , 300k, same mufflers!
    @aero3113 my top priority,  with no particular knowledge of boat cooling systems either way, was fresh water cooled. I knew most of my boating would be fresh but probably would be coming out of salt. I think Tikki sent me down that wormhole. Wonder what happened to him? He was super involved on the site and went poof!
    You're closer to Mickey and Goofy than salt water lol
    edited September 23
    I got the heads installed today, adjusted the valves and installed the starboard side exhaust flappers. I’m having trouble aligning 2 out of the 3 bolts on the front bracket of the port manifold. I almost think I’ll have to drill the holes on the bracket a little larger. I loosened everything up but still no luck. They’re so close to aligning! I  got frustrated and gave up for the day. I was hoping to get the manifolds and risers on also but I ran out of time. I made sure I got the spark plugs in without the exhaust manifolds on! Lower intake manifold and new injector O-rings arrived. Hopefully I can put that all together tonight.
    looking amazing
    Looks great
  • Rich_Rich_ Member Posts: 366 ✭✭✭
    Quick turnaround. Now we just have to get through this little storm
    Yes @Rich_ !!
    She sounds like a sewing machine!
    I had small leak on the port side riser when I first started her. Retorqued and all was good. 👍🏻 ⚓️
    Good luck to everyone
    It doesn’t seem like it going to be as bad as they originally said. It’s the surge that might be the issue.
    The surge is actually always the issue...living in Florida most of my life....only costal when I was very young..Coco Beach..hurricane Donna I belive it was....but the rest I would take over tornados, flooding we see every year on the news in other areas of the mid west etc. I did do a few years in ND, also middle east . We did have a tornado through our town here in Florida killing a couple people so we do see it- my first in now almost 70 years and that was 20 years ago...it is that storm surge that takes homes off their foundations so depending on where, when it hits as far as high/low tide and how homes are constructed..these areas have been there before and hope are all OK!
    Full moon tomorrow also….
    Wind is not the real issue per se. Wind blowing the water into a funnel and the tide not draining out is a problem.
