Pulled her, have a project to work on….
1…567810
  • aero3113aero3113 Member Posts: 10,034 ✭✭✭✭✭
    Got all of the injectors cleaned. The injector test kit really works well. I’m sure it’s not as good as a professional cleaning and test but does the job. I have no clue what happened to this injector. Almost looks like it was melted on one side. It tested good so I’m going to run with it. (By the way, this is my 10,000th post! ⚓️
  • YYZRCYYZRC Member Posts: 5,548 ✭✭✭✭✭
    @aero3113 buy this boat just for the motors!! 330 with 496s - wow!!
    https://www.facebook.com/share/1CGYenXdbo/?mibextid=wwXIfr
    I saw this yesterday! I also saw it listed a few months ago. I wonder why it’s been listed so long.
    Description says the motors need to be rebuilt. Scary for most people I guess.
    I don’t see that stated in the description?
    Sorry my bad it was in the comments on the Rinker boat owners group. Sounds like the seller is motivated.
    34k for the boat that needs 20k worth of motor work....id also be a motivated seller.
    I removed the lower intake this morning and cleaned/painted the upper. Will give the injectors a cleaning also with the injector tool I bought.
    Better hope the wife doesn’t want that towel back….
    lol!
    I have about 4 of them I use for stuff like this. Weird thing is I don’t know how/when I started using them. We currently use the same ones in our bathroom now. My wife hasn’t said that there’s any missing so I guess I’m good!
    edited October 26
    I received the new lower intake for the starboard engine today. Will try to put the injectors, upper intake, throttle body and thermostat on it tonight.
    Ready to go back on
    edited October 28
    Some fresh paint on the valve covers. FYI: Amazon has the Rustoleum Engine enamel for $5 less than Home Depot.
    https://a.co/d/0irYsF76
  • captkevincaptkevin Member Posts: 605 ✭✭✭
    Looks great
  • rasburyrasbury Member Posts: 9,012 ✭✭✭✭✭
    Thanks aero for the posts. We all learn a lot following your "tribulations" and fun!
    I ended up replacing that injector with a cleaned and tested one I bought.
    @Ian " hope the wife doesn’t want that towel back…." I have a few of those towels I'm not sure what to do with..
    @aero3113, I'm looking at your pictures of the intakes with particular interest..i could not reconcile in my mind how your intake looks vs how I remembered mine. A couple pages back I see a top view of the upper intake off the motor. The area I'm looking at is where the rotor goes through. That webbing area is where i have significant corrosion from the out side as I'm closed cooling. I need to go to storage, remove the rotor cap so I can get a better look and wire brush the rust- see if it's repairable. I need to figure out how to divert the water coming through that compartment.
    Before you remove the distributor, vacuum as much of the loose rust up. Pull the distributor then tape off the hole then wire wheel.
    edited October 28
    Let the paint cure the spray with a corrosion protector to keep it from corroding again.
    edited October 28
    I installed the intake today. Ran into an a slight issue. The valve covers I painted, I bought on eBay to replace mine. They were a little rusty and seemed better just to buy different ones. Well, the ones I bought were both left side covers. Never knew that they’re different. My fault for not realizing. I found a different set and now have to wait for them to finish putting everything back together. I also saw that my original covers and the eBay ones were painted inside. My port side weren’t painted inside and the second eBay pair aren’t either. The ones for this engine were bubbling and I just touched the bubbles and the paint started flaking off. This could’ve been a big issue!
    And here I thought I had bum luck!
    This is what makes it fun, right @YYZRC ?!🙄
    Well that just sucks. As far as mine, I  hopefully can just pull the rotor cap to get to it as i dont want to pull that rotor if I dont have to. Those are torrag screws for that cap? I know i replaced the cap/rotors and wires a couple of years back...
    They’re Torx screws.
    I went and took the FJ40 out for a drive and it felt like the brake master cylinder was failing. The brake pedal would drop then catch lower to the floor. Luckily it has a dual brake master cylinder!! Parts on order. Maintenance never ends!! LoL !!
    Rrrriiiigggggghhhhhhttttttt!
    Belated congrats on the 10,000 posts that is quite an accomplishment
    edited October 29
    Better make sure its not one of the 4 brake cylinders on the rear axle!
    If not already done i highly recommend a rear disk bake conversion.  Im not sure if they make it for the LC axle but on the 4runner/taco theres a conversion that uses stock 3rd gen 4 runner rotors, u bolt flip kit and i think 2011 Saturn suv rear brake calipers.  These have electronic parking brake accuators as the stock fj40 transfer case parking brake drum isnt exactly the greatest.
    @PickleRick , I’m not losing any fluid so I’m pretty sure it’s in the master cylinder.
