What off-season projects are on your wish list?
LaRea
Member, Moderator Posts: 8,013 mod
Well, unless you are one of those fortunate boaters who lives close to the equator, your boating season is probably over. I'd be interested to hear what off-season upgrades or renovations people are planning.
I need to service my outdrive rams, which no longer have enough power to raise the drives when I'm on plane. And I want to adjust both of the outdrive trim gauges to give accurate readings.
Also, I'd like to add more grab rails to my hardtop. Walking along the gunwales is a bit of a balancing act, and I think I've tempted fate long enough on that one.
Anybody else? I know @diggin2day1 is looking at helm electronics, and @Michael T always has something up his sleeve.
@LaRea - since you asked....yes, up my sleeve I do have at least one, maybe two tricks. I am installing a third Ocean LED Pro Extreme 8 color changing underwater LED. I got the green light from the Admiral this morning. As the pictures I posted in the past have shown I have one of the units at the outer edges of each side of the hull, underwater about 8" directly above the trim tabs. This worked well and looked great.....but the stern drives block part of the light spread. The plan is to install a third one at the same level as the other two between the drives for a full spread effect. If I can find a picture of the Ocean LED pro 8's on the outer hull edges I'll post. BTW at the bottom of the picture you can see the Rinker factory o.e.m. Ocean LEDs that came with the boat. They are fine but I wanted crazy! When both sets are on (all 4) with the uppers strobing the fish are neurotic - really, it's too funny. Some of them turn upside down. keeps the grandkids mesmerized too.
Also, last year I extended the mattress in the front berth 14" using the same combination of dense foam topped with memory foam as o.e.m. The Admiral got some of the same fabric as the factory o.e.m. and the mattress cover looks completely "factory". To support the increased mattress length I had a 3/16" aluminum plate made to extend past the o.e.m. edge of the front berth. The Admiral added a custom 4" thick topper over the mattress. We now have a bed that is a lot bigger - about 6" wider than Queen size and about 4" longer than King size.....and way more comfortable. We can sleep on it for a week running with no issues. This winter the Admiral is going to change the draw string mechanism she originally designed (see picture below) to make the mattress duvet wrap tighter around the leading edge of the mattress and topper, for a more custom look. This was a huge improvement for me as i wasn't getting a good night's sleep before the mod. I can put up with a lot but not a bad night's sleep! The pictures of the bed are right from the factory and after the Admiral's work. BTW no knock on Rinker factory o.e.m. mattress. It was WAY more comfortable than most I tried. I'm just real picky and real long LOL - 6'6".
2=install 4 new batteries
3=install my new scotty downriggers
4=install led lighting throughout
5=clean up engines/bay
6=install inverter
7=install BBQ
8=fix all the little things
and have a blast cruising around on my new boat
1) New dock built
2) Just get the boat in the water
3) Find someone to help with props who knows what they are talking about
MT, I'd be adding some room-darkening shades on those side windows!
detail boat
completely service out drive
Order boat lettering for renaming boat
Find a trailer(help! Post coming later)
fix one trim tab
vessel view or merc monitor
uodate audio system
06 Rinker 270
Big list....
Major top to bottom polish and clean
New decals/pinstriping
New GPS
New speakers
New head
LEDs throughout/running lights
New bellows/seals
New camper top, or at very least the front windshield part/some stitching.
I'm prob. being a little too fussy, but that's the way I am. Hopefully can swing whole new camper top.
06 Rinker 270
Biggest job list: @BellevilleMXZ
Biggest job budget: @Handymans342 (for the dock!)
Best plan for off-season cruising: @Alswagg
OK, back on topic. My off-season projects, well, not sure I have any except to fix my bilge pump. End of season it started popping the breaker. Should be an easy fix. I've also been thinking about replacing my TV/DVD cause it seem really picky about what DVDs it will play. It's that or put a small player in the cabinet.
Everyone knows Ski-Doo rules!! ;-)
Gotta keep working out over the winter so I don't look like a mess at Jobbie Nooner next June.
