Yeah, agreed that it's not cheap. I have a drill pump but its awkward to use (one hand on the pump, one hand on the drill - otherwise the drill pump spins and yanks the water line). Totally fine for doing ACs but no good for trying to winterize a jet boat on your own.
Crazy enough we finally got our new boat 2011 Formula 45 Yacht 2 weeks ago thank god for this extended fall. Got some nice drone pictures this evening and use out of this boat before it comes out next week 😉. ThebRinker 400 was a great boat but this feels like the big brother to that boat.
2008 Rinker 400 EC (sold Aug 2025) 2015 Scarab 165G Laser Sailboat 2002 Seadoo Explorer 2023 Seadoo Spark Trixx x 2
lol!! I’d have better luck trying to lift it myself 😂
Yea, I usually figure out a way to do anything by myself. When we get to the dock, my wife always asks me if she can help...i basically just try to get her out of the way so she doesn't get hurt.
Having never been around a boat yard. I'm always amazed and suspicious how boats stay secure on a few points on those stands. I had assumed a lift of some sort , the big rolling ones to get them out of the water- while setting them down on the stands. How did you move your boat and how the heck did you get it on the stands? I've never understood how the hulls handle the stress of sometimes i see 3 points....and then have a nore eastern come thru with 60 mph winds....I'm just a fl boy for sure..
Most of the weight is on the blocks in the middle, with the outside jack stands keeping balance and some weight. But yes, I agree it just doesn't look right.
I replaced the power steering cooler today. Since it was out, it was a perfect time to clean the ground terminals on the back of the block. It was pretty easy to access the cooler with the intake off but still awkward. I’m going to clean the port side grounds when I get a chance.
I replaced the steering actuator this morning. Not a tough job but the hardest part is getting the lower mounting bolt out and back in. I think since my intake is out, it made it easier to get back there. It’s hard to see in the pic but the holes for the pins were slightly elongated and there was slop.
How much slop did you have in your steering? Between that and the steering fluid leak I have, I'm considering swapping the actuator and cooler over the winter.
@grouch0jr , I didn’t have any slop that I noticed at the wheel, it was more when I moved the drives by hand outside the boat. I had a leak also. I saw a drip at the bottom of the actuator and I didn’t want to take a chance if the cooler was leaking also.
There is no adjustment in the actuator correct? At slow/idle speed i constantly play with the steering wheel- it stays in place but the motor is back and forth...i replaced the pin but it had no effect. Its been that way since I bought it with 50 hours on it...
Our 270 did the exact same thing. At idle speed it would hunt back and forth. Partly I think that big deep bow, partly the single engine because even though it had counter rotating props there was still some torque in play.
2015 Scarab 165G
Laser Sailboat
Great pictures 👍🏻👍🏻
