Discovered that the anchor locker drains are about 3" above the base of the anchor locker, meaning there is always standing water in there. Forgot to take a pic. Will likely end up filling the holes and re-drilling them 3" lower.
I don't understand why they did this! The drains are well above the waterline (even when plowing a lot of water). Waffling between filling and redrilling the drains vs building up the floor of the anchor locker with foam and then a couple layers of fiberglass. Either approach is easy since the PO cut 1/3 of the bulkhead away!
Definitely cannot leave it as-is since the anchor locker is not sealed off from the cabin, meaning that moisture (mold) is impacting the cabin as well.
@tricountytrail it is almost certainly mounted on the starboard side of the anchor well. If you remove the starboard speaker you should be able to access it.
So only 2 wires coming from the front of boat on my 360. Its not under dash or any where in front of that. I double checked the engine compartment only place left is under helm seat or behind ice maker. Anyone know where it is on a 342? Still trying to find windless solenoid???
Picture of actual wiring coming from front of boat then travels all the way back thru cabin and into helm.
Looking good!! ⚓️
Edit: despite what you might believe, my thumbs were not enhanced.
https://www.greatlakesskipper.com/rinker-boat-hard-top-tower-114-1-2-x-49-1-2-inch-white-scuffs
I paid almost $7000 and still the best upgrade I did. Do it, @aero3113 !!
If I installed a hard top, I wouldn’t be able to have the boat hauled to the house. It would be too high.
As for that wire, maybe trim solenoid? Fuel pump?
